Hi All
on Sunday whilst removing the wires from the old jap sat nav from under the 2m thick carpet/sound deadner :D a plug was found protruding from my ECU..
aftermarket ECU hey????
this is a long shot but anyone have an idea as to what ECU this plug is for???
be good to just plug an play
Cheers in advance
Ian
https://www.sau.com.au/forums/topic/105932-found-aftermarket-ecu-plug/
:) Wolverine
will have to shove a screw driver in and see if it launches
or just connect it to the 260rs that apparently lives round the corner from my place....
hopefully its for something worthwhile but hey e'll see...
How are you Michael??
oh, better have a look
Seriously though, is it connected by splicing into the 20 or so wires that come
out from the ECU ??. If so, you should be able to at least determine which
function its intercepting (without dismantling the ecu, but that would be fun :P
?? (eg tach, afm, ???) of course that needs a schematic, but its probably a R33 std ecu.
humble, i'm good, but missing the staj
That's not a plug. it's so the certain signals can be sent to multible places. I found 2 behind the speedo in my car, and that had 1 speed sensor in, and 3 out (ATTESSA, ECU, HICAS). Dunno why yours is at the ECU, maybee there was something like a Super AFC, and when they removed it, they put that in to pass the signals back to the ECU.
Yeah I just found the exact same plug near my ecu last night when I was hooking up my a/f ratio guage. And probably half of my ECU wires are spliced into but I have a HKS turbo timer that has every single feature hooked up which would require quite a few of the signal wires spliced into so not sure if they go to this plug or not, it was taped up and I couldn't be botherd checking it. It may well even be the plug for the turbo timer.
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
