Hi mate, we have loads of silicon hoses, reducers and elbows in stock, and all can be purchased online via our website and delivered to your door.
http://www.justjap.com/parts_nhoses.htm
We are based in Kirrawee, near Sutherland.
Regards,
Steve
Regards,
Steve
I require them today and your just ova an hour away... I poped in last weekend!
Thanks Guys, I will be down to just jap, but can't get down there for the hoses...
Thankyou
for the hose i would go to www.shiftperformance.com.au They have many shapes and sizes.Also they are at lansvale hume hwy about 5 mins from livo going to the city/north bound,side..
ahh ok, that would have been handy, but went to GCG and got the parts...
Gotta get to Just Jap for some camber adjustment Bars on the rear...
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
