Cleaning out my shed, this stuff has to go!!!
R33 Stuff
Suspension...
Std Castor rods $30 ea on hold (burnfest)
New Adj rear camber arms $200
Apexi T max height and damper adjustable coilovers (Set) $800 (SOLD)
Ohlins Height/damper adjustable Coilovers with helper springs (rear only) $250 (SOLD)
LSD Diff good nik $200
Interior..
Custom ally fire extingiusher bracket. Bolts under drivers seat. $50
Boot Trims $80 for all I have (a back, a lock cover, maybe a side or 2)
EL Dial kit for GTST $100 on hold (twintipd)
Dash Panel (yes the whole thing that goes over the dash to centre console) $80 jus needs paint
Dash panel (same as above but in 2 pieces) all switches and vents $25
Guage cluster surround (painted a dark silver) $30
Set of rear carpet in good nik $75
Engine...
Stock GTST cooler $50 (or a carton of Boags ST George)
Side pipe with stainless steel tip. Mega Phat for track days. $100
R32 and R32 GTR stuff
Set of 6 stock GTR injectors $350 (will not separate the set) even come in Sard boxes!! SOLD
NEW HKS Style s/steel dump pipes for 32/33GTR. With studs and gaskets $350 (SOLD)
Standard RB26 cams good nik $150
GTR/GTS4 castor rods (standard) $50 ea
Std RB 26 ECU $300
Std RB26 Cam gears (suit any RB) $50ea
Steering column plastics $20
MISC
Carrozeria (pioneer) 6 disc stacker $100
Used "old style" Jun cam gears (steel ones) $200 IN and EX to suit RB!!!
Set of 4- R33/S14 5 stud stockies good rubber $300
HKS EVC valve control box and Wiring, No brain bit... $ carton of Corona
GTR TURBO's AND MISC ACCESSORIES
RB26 STD turbo manifolds $75 ea
RB26 Std AFM's $75 ea
Pair of M's (K&N) Air pods with polished ally intake pipes Suit std afm's $200
Pair of Turbos in good nik Minimal shaft play $300ea Or the pair with stock dumps for $620
R32 GTR fuel Pump $200
Stock GTR Dumps $20ea
Pair of TRUST Greddy Type S Bov's on GTR Pipe (bolt on) $450
Pair of RB20 Afms $70ea
Polished Turbo outlet pipe $100
Some pics attached
Call or email me for pics or purchase.
eon@westnet.com.au
Eon 0409 117 081
Edited by CMS Drifter
pics please of :
to skylinegt_66@hotmail.com
cheers....
armbrusb- what your email addy and I'll send you a pic. Yes it bolts directly to the sidepipe. Exits the car jus in front of the lh/r wheel.
I fitted a small bracket under the car to support it.
cms
