My mate has a Cordia Turbo apparently running "20psi" on a 2L engine...he doesnt have any other real mods that he knows of (he got it off a mate for free) and the car isnt well taken care of.
So do u reckon it would beat a R33 GTS-T cause I dont reckon it would but he reckons it would smash a 'line.
Another thing...this guy reckon skylines dont come out stock with intercoolers....
https://www.sau.com.au/forums/topic/10599-cordia-turbo/
the fact that he got if for free should tell u it s a piece of shit! And 20psi hahahahahahah good luck to him!
https://www.sau.com.au/forums/topic/10599-cordia-turbo/#findComment-170766
dunno if you've seen the cordia turbo but compared to a skyline the exhaust wheel is about the same size, but the compressor wheel is tiny, it must be at least 10mm smaller!
Good luck to your mate we were blowing holes in pistons at 18psi
They go ok but won't beat a halfway modded liner.
https://www.sau.com.au/forums/topic/10599-cordia-turbo/#findComment-170927
I use to own one, theres no way it could handle 20psi if its stock, and if it weren't stock why'd the guy be giving it away!
The 1.8L ones don't have factory intercoolers, been a 2L i'd say it would have a intercooler as im sure the 2L Jap Dash engine has them stock like the VR4 motor, could be either of them, or a Starion Sirus motor which doesnt have an intercooler stock either...
But any of those engines handling 20psi is just wrong without alot of work/rebuild etc, the age of the cars and the fact it "isnt well taken care of' is just proof.
it's BS if you ask me!
Cordia's are quick, for there time and technology i'll give them that, good bang for your bucks cars..
and tourque steer can be fun :D
https://www.sau.com.au/forums/topic/10599-cordia-turbo/#findComment-171707
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
