It has been discussed somewhat in old posts, but I would like to get some recent feedback on syncro gearbox options for street driven GT-Rs. I'm NOT interested in going to dog engagement gears, so I figure that leaves:
1. Replace/rebuild standard gearbox as required. I guess that this is the most common practice as it works out cheapest. Reliability will obviously depend on factors such as abuse, main duty of car (drag racing etc) and torque.
2. OSG helical gearset with syncros. These would appear (to me anyway) to be basically the same size and design as OEM Nissan gears, with the benefit being that they (theoretically) are manufactured with higher strength due to their metallurgy and finishing.
3. PAR straight cut gearset with syncros. If you believe PAR's caim on their website, the large tooth profile means that there is added strength and reliability in going to this straight cut profile. The downside is the noise, however in theory this should only be in 1st, 2nd and 3rd gears (4th is 1:1 ratio and 5th will retain standard helical gears).
I would appreciate feedback on the OSG and PAR options from people who have tried the products. Any premature or unexpected failures?
Cheers
Gav
https://www.sau.com.au/forums/topic/105996-gtr-gearset-options/
ppg also make a synchro GTR box i think. most people i know who have used both, favour there product over the PAR ones.
from what i know the other difference the OS box has over stock is the tooth pitch is different. slightly 'straighter' profile so there is a little more gear noise than stock. i have one in my car, but only running around 250rwkw so as expected no failures or problems. i can say it's not as easy to shift when shifting slowly at low engine speed as a stock box, but at high RPM with faster shifts it is beatiful to use. i'm also running a OS solid centre twin plate, which may be half of the driveability problem, but it is not that bad (the box i mean).
i reckon someone in w.a should start selling some cheap gearsets and they would be millionaires :P or even second hand gtr boxes as they will be breaking like twigs between u, simon, bobbo, mine and a couple of other high power 26's haha :P
Edited by CruiseLiner
Auto Gallery Yokohama make a double syncro coned gearset...
http://www.ag-y.com/english.htm
I think Auto Gallery yokohama just do a double syncro conversion. They also upgrade gearsets...but I'm pretty sure they use OS Giken gear sets.
One think with the Giken gearset is that 1st is so damn tall. It would be a pain for hill starts and driving up driveways, especially in a heavy R33/R34/Stag with biggish cams.
The size and tooth profile of the OS gerset is vastly different from the Nissan design.....big thick chunky teeth.
Im leaning towards the PAR, simply for value for money reasons. It looks like a very strong box, and they guarantee it up to 750bhp. It costs less than $5000 for them to rebuild the box with new gearset and a freshen up of the box (new bearings etc).
Have seen one installed in a GTR, the owner said driving it was very similar to the stock box. The only real downfall is they are -very- noisy 1st through 3rd.
Amaru: OS Giken 5 Speed Gear Set all the way for me, I know of PAR and Sam the owner and im not a fan of his designs or buisness sense.
NissanFreak
Haha...I was going to post something along those lines, but you beat me to it.
Strange how he doesn't put his name to his gear anymore...
Oops - my bad, shows that it's dangerous to assume! I would be keen to see a set of OEM gears next to the OSG set.
With regards to the OSG set, I remember Mario basically writing them off as a waste of time (actually sh!te was the term he used I think), but I guess it depends on what the ultimate use is and how they're "abused"
il second that. my little ts2bd clutch is feeling the strain. just like taking of in second :)
nice con rods too. all the meat in the right place. did he tell you no one here buys his stuff. and that it all goes to the states? :lol:
I have a PAR gearset in my S15.The standard set didnt like 250rwkw much.So far no problems,feels strong,a bit noisier,drives like standard.Cost me $4800 all up with delivery to NSW and back,with them rebuilding the box.
I think I'll be using the OS set for my GTR though.
Sam doesnt return calls but he does reply to emails.
Anyone used his rods on a GTR???
Here's a picture of the OS Giken Gear Set. As far PAR rods one comment "they are way too heavy, anyone can build a strong rod if they dont take weight into account" and because of this PAR rods in a high rpm RB26 it would put extra load on the bearings etc.
And my engine builder also said that he once ordered a set and one rod was 1mm shorter than the other three, had him dumb founded on dummy assembly why his squish was out on one cylinder LOL.
Anyway as people may have guessed I am not a big PAR fan.
NissanFreak
Edited by NissanFreak
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
