  • Replies 50
Posted Images
Hey I just bought my R33 GTST and was looking forward to meeting some skyline owners from Newcastle area so i could meet and get some ideas on what to do to my skyline to have maximum affect cause i don't know what iam doing cause its my first turbo car yeah i seen the light thanx and hope to meet you guys soon.
thanx Joe
Hey JT im from neiwe too and I saw ya driving your beast today. I think u were hjeading to cardiff? I was in a silver lancer next to ya. dunno if u noticed. but yeah when i get my line back we go for a cruise :P
Phil
Im in adelaide is that close enough??????
Really I use tolive in Newcastle and now in Adelaide and NOW moving back to Sydney for work haaaaaaaaaa! Cruzed around newcastle a few years ago in my red r33 gtst with South Australian number plates and only seen 2 skylines i could not wait to get back to adeliade to get my import intake, bla bla any way will bring the GTR to Newcastle to see the folks and bring out for a drive to meet some of you lot as I need to make new friends. Any back to the real question and answer as most know doing up a import is not that hard for bang for bucks .
I reckon Full exhaust and i mean turbo back you lose around 20+ kw if you leave the standard front pipe on and only put a cat back exhaust so do it right if you can and do the whole lot in one hit . Next if you have standard air box leave it as this is the best unless you like the sucking noise just replace the filter to a K&N style this reduces heat and allows good air flow with cleaner air. Front mount dont need to go stupid in size look into it GTR intercoolers are a good option but notthe best and if you look hard enough you will find cheaper. Final is a boost controller i use to have a AVCR i loved it not saying this is the best but it looked good too. with this and a good dyno tune should see your self between 220 and 250rwkw just my thoughts. Want to go nuts on mod your car go to the extream pull the motor out put a RB30 bottom end with your rb25 head power fc which you will need and a 3540 turbo larger injectors bigger fuel rail forged pistons etc list goes on plus will almost need a application for a personal loan. Good luck
well thanks for that nice to know hope to speak you some time but Hope to get more information out of you though :D
Lol. Sorry.:D
Yea the Ceffy's pretty stock atm, with 3" from the turbo back, front mount, Profec B, pod filter.
Dont drive it much these days due to boring company car, that comes with free fuel :)
Big plans though, Power FC, GT30 maby. Anyone got a RB20 block i can have??? :)
Peace.
Lol. Sorry.:D
Peace.
hope to meet up with you lot share some stories of adelaide etc :D i love this smile icon
hey d-d
which stagea did you see in town today?
as there are 2 series1 both silver that get in their..
if it was the one with the front mount that would be me
if it wasn't then it would have been beastien..
I actually think i saw you this arvo
im from newy aswell, just moved here in january... seen quite a few clean lines gettin round... havnt made it to the foreshore yet...belmont area... might see a few of you guys there next sunday if anyone is in there :laugh: have a white S1 R33 "ATY..." plates
Edited by Ezz35
we should be in this sunday.
we usually try to get in for a couple of hours
by the time we drop the kids off we
usually don't get in til later in the arvo.
but pull up and say hi sometime.
you can't miss us
just look for for the fmic
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
