Hey guys, just been searching the last 30mins on cold air intakes for r33's. But i still dnt know what sort of bends i should use for the piping.
I have a fmic now so i can use the std hole, does this hole need to be enlarged or will the size (2.5"?) suffice???I have a type m front so i can use the hole in the corner of the bar as my feed.
Should i get one 90degree bend in the middle, or would straight - 45 - straight do a better job?
Im thinking of using flexi-tube or pvc, do you goes mesh the piping? so big things cant go through or is this not worth the hassle/cost?
pic below, lol done it in 2mins so bear with me hahah
Edited by nsta
I used the same hole saw i used for the FMIC piping install to make it a bit bigger, and then drilled another hole right next to it, so there's about a 3" by 5" hole. did taht make sense?
I've seen a lot of pvc pipe used.
I don't use any pipe at all - it's still sucking cold air from outside the engine bay, as long as you have a sealed box setup. i just didn't see the point of an "air ram" when you're already running a compressor after the filter anyways...
look here
and here
Nsta - i don't just use a heat shield, i have the pod in a sealed box, the only opening is the large hole at the bottom.
As that hole is the only way for air to get in to the box, i don't see why you need a pipe to help it get there? the stuff is generally fairly good with finding directions :)
That said, lots of guys use pipe.
I figured that the air below the airbox (just under the hole) is under pressure anyway - if you're moving forward, air comes through the front bar and hits the plastic guard that sits on front of the tyre (the grill that stops mud etc getting on the back of your old side mount intercooler).
So the air would head into the airbox with the sucking filter, as it's the path of least resistance.
standard hole is about 2-2.5" diameter. Might be a bit small and cause a restriction? i don't know - someone must study flow dynamics on here!!??
Edited by Beeble
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
