I put mine on tonight, 18's with 265's out back and 235's up front, they look TOUGH. Now to get it lowered... Stay tuned for pics =D
Was at the servo checking the air and had some guys walk past and go 'check out that dish'. That makes you feel warm inside ^_^
Buy them, you won't regret it!
Edited by ActionDan
https://www.sau.com.au/forums/topic/106087-impuls/page/2/#findComment-1994564
  • 3 weeks later...
looks nishe dan...still tryin to decide what i want..
i like the TE37's but they're fkin expensive as...
LMGT4's look good as well....
then there's the cheaper option of the lenzo muse which is a copy of the AVS type 5 or somethin like that...
https://www.sau.com.au/forums/topic/106087-impuls/page/2/#findComment-2036732
Yeah I'm looking at suspension and zorst now, suspension first though as 18's bumped up the ride height a little. I wont need FMIC, I only intend on 10psi and that'll be handled easily by a R34 GT-T Side Mount. Keep me posted =D
https://www.sau.com.au/forums/topic/106087-impuls/page/2/#findComment-2036766
I'm fitting Bilstiens and king super lows in the next few weeks when I get around to it but I'd suggest you will be pushing shit uphill personally. The inner lip of the guard eats into available space considerably on the rear. Depends on rubber size too, 235's seem to be almost the limit up front, 265's squeeze in on the back (9.5inch wide out back).
Hope that helps.
https://www.sau.com.au/forums/topic/106087-impuls/page/2/#findComment-2060160
hey Dan it looks like your rear drivers side wheel is gunmetal grey and the rest are shadow chrome. I had the same problem with my impuls but sent the wheel back to tempe and they replaced it with the right one free of charge. I've seen the same problem with several other cars with impuls.
https://www.sau.com.au/forums/topic/106087-impuls/page/2/#findComment-2060349
Mint: This is a lighting issue. As the rears are so much deeper, they tend to look darker. (The apssenger side is exactley the same. In the right like they look even. I also bought these 2nd hand so won;t be able to have tempe o any swaps.
Jim: That looks like a hack job! I Hope someone is gonna edge that properly so it dosn't rust or slice open ya tyres!
Cheers
https://www.sau.com.au/forums/topic/106087-impuls/page/2/#findComment-2060479
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
