I put mine on tonight, 18's with 265's out back and 235's up front, they look TOUGH. Now to get it lowered... Stay tuned for pics =D
Was at the servo checking the air and had some guys walk past and go 'check out that dish'. That makes you feel warm inside ^_^
Buy them, you won't regret it!
Edited by ActionDan
https://www.sau.com.au/forums/topic/106087-impuls/page/2/#findComment-1994564
  • 3 weeks later...
looks nishe dan...still tryin to decide what i want..
i like the TE37's but they're fkin expensive as...
LMGT4's look good as well....
then there's the cheaper option of the lenzo muse which is a copy of the AVS type 5 or somethin like that...
https://www.sau.com.au/forums/topic/106087-impuls/page/2/#findComment-2036732
Yeah I'm looking at suspension and zorst now, suspension first though as 18's bumped up the ride height a little. I wont need FMIC, I only intend on 10psi and that'll be handled easily by a R34 GT-T Side Mount. Keep me posted =D
https://www.sau.com.au/forums/topic/106087-impuls/page/2/#findComment-2036766
I'm fitting Bilstiens and king super lows in the next few weeks when I get around to it but I'd suggest you will be pushing shit uphill personally. The inner lip of the guard eats into available space considerably on the rear. Depends on rubber size too, 235's seem to be almost the limit up front, 265's squeeze in on the back (9.5inch wide out back).
Hope that helps.
https://www.sau.com.au/forums/topic/106087-impuls/page/2/#findComment-2060160
hey Dan it looks like your rear drivers side wheel is gunmetal grey and the rest are shadow chrome. I had the same problem with my impuls but sent the wheel back to tempe and they replaced it with the right one free of charge. I've seen the same problem with several other cars with impuls.
https://www.sau.com.au/forums/topic/106087-impuls/page/2/#findComment-2060349
Mint: This is a lighting issue. As the rears are so much deeper, they tend to look darker. (The apssenger side is exactley the same. In the right like they look even. I also bought these 2nd hand so won;t be able to have tempe o any swaps.
Jim: That looks like a hack job! I Hope someone is gonna edge that properly so it dosn't rust or slice open ya tyres!
Cheers
https://www.sau.com.au/forums/topic/106087-impuls/page/2/#findComment-2060479
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
