From their site the maps look like this , though the turbine map should vary with different compressors at this site it does not .
So you have ~ 21.5 lbs of exhaust flow if it has the .86 a/r exhaust housing or ~ 18 lbs flow if it has the .64 a/r housing . The energy recovered by an efficient 54mm turbine has to try and muscle a 76mm TO4S dinosaur compressor wheel that has the capacity to pump 49 lbs of air in its .70 a/r TO4S cover . That cover by the way if used on a GT35R can pass 60+ lbs of airflow and approx 75 lbs on a TO4R/Z so way overkill for 49 lbs .
If you look at the compressor maps for the GT2860RS and GT2871R 48 trim they show 35 and 38 lbs of flow from a 60 and a 71mm compressor in a .60 a/r TO4B cover .
The point of all this is that more modern compressors are far smaller than the dinosaurs for adequate flow and the comp covers or housings are more compact as well . The GT28 turbine is a high speed device as are the GT series compressors , the fact that they work together at high rpms means they compliment each other . The TO4S compressor from the GT2540R or GT2876R as Garrett now calls it is way out of step technology wise with its GT28 turbine . It has reasonable airflow for its size and trim but pumps it volume because it is big rather than efficient - for its airflow . It doesn't need high revs to work but the GT28 turbine does so this is where they fight each other and the result is boost lag .
The Garrett site said - best suited to unique applications , not recommended for general performance applications .
I don't know where you go from here , your compressor wheel and cover are the problem so its a case of change them or change the turbo to get better response .
Probably not what you wanted to hear , why those turbos are on the market at all beats me .
Cheers A .
Edited by discopotato03
There's no need to upgrade your turbo, just come down an exhaust housing size to 0.64 & u will be far better off. As much as the GT25R doesnt look good on paper I have been impressed buy how it performs so far in the real world.
first thing i would try to find out is if:
A ) this characteristic is normal for this turbo, on this engine or
B ) its abnormal for this turbo/engine combo to get this sort of lag
i had a lag issue on my sr20det car that had a gt2530 turbo, i was spooling early on in the range, but would take 5K rpm to hit 1bar of boost.
after ALOT of fiddling around it was found that the wastegate arm didnt have enough tension on it, so when the pressure built up in the exhaust housing, it was opening the wastegate early and causing a sort of wastegate creep. unplugging the vacuum line from the wastegate didnt affect it because the pressure opening the wastegate flap was in the exhaust housing itself, not from the vacuum feeds positive pressure.
so in saying all that, check that the wastegate arm has tension on it, if its an adjustable arm, give it around 1-1.5cm of tension. disconnect the vacuum line from the wastegate, and give it a run. if boost response is better, then you are in category B, same as me, which is easy fix. if not then follow the advise given on this thread, specially get your tune checked out !
after i fixed this issue on mine i started spooling earlier and hitting 1bar at 3.3k rpm WITHOUT a tune :D
Edited by mokompri
LOL....Ok :)
But i never even get near 5,500rpm in day to day driving. so i suppose when i hear bottom end i think the rpm you are pulling in traffic ;)
When you are up the thing, who really cars what your bottom end is like, its only in day to day hustle and bustle when i need to shift back to 2nd at 45km/h to get past a car i curse the RB20 :/
Looks like you have just taught yourself a lesson about the benifits of a rb30det. My 3 litre can overtake cars at 45km'h in 4th or 5th gear off boost.
I use to work at Hinterland toyota, so I got to drive the Sportivo corolla's and the celica's with the VVTL-i, so I know what you mean.. But this is alot worse than waiting for the valve lift just to kick in... i'm talking absolutely gutless off boost... I honestly think if I raced a sportivo corolla and started off boost, it could take me out :|
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
    • No, I don't remember the exact reasoning (was 20 years ago!) but the cops didn't end up supplying it to us either. Actually my mother went through a similar thing recently where she was hit when stationary, flustered and didn't get address (she got plate details, name, phone and insurance company, but not address). Person who hit her blocked her number and their insurance company (naturally) would not provide any details. Her insurance company also required her to pay the at fault premium because she did not have the address, cops did not help as it is a minor civil matter (they said their only course was if the other driver had left the scene of the accident without providing any details). She only ended up getting that refunded because they happened to be insured with Suncorp and she was with APIA so same company owners. For some reason the address is critical in insurance companies recovering money from the at fault party
    • If you're driving something like an R32 through to R34, no chance of meeting Euro4. Euro4 came out in 2006, and car manufacturers back then were complaining how hard it would be to meet those regulations. Not a chance a vehicle 10 years earlier is going to be compliant.
