Item:JVC LH915, plays mp3/wma/cd, accepts SD cards as well, make your own graphic to display on screen, change colour of screen, many features, see listing from jvc site, or below.
Item Condition: very good, no scratches, 6 mths old, sorry lost remote
Reason for Selling: sold car
Price and Payment Conditions: $280 ono
Extra Info: very new
Contact Details: PM
Play back MP3/WMA files or show PICT images on the 3D Wide Display directly from an SD card -- without burning the data on CD. The MOS-FET power amp and 24-bit resolution Burr-Brown 1-bit DAC deliver superior sound that can be customized with 3-Band Parametric iEQ.
Highlights
- Power Output: 50W x 4
- MOS-FET Power Amp
- SD/CD PICT (Personalized Image Capture Technology)
- Application Software (Image Converter WIDE)
- 3-Band Parametric iEQ
- 24-bit Resolution Burr-Brown 1-bit DAC
- HS-IIIi Tuner
- MP3/WMA Compatible with ID3/WMA Tag (CD/SD)
- CD/CD-R/CD-RW Compatible
- 5V Line Output Level
- Gold-Plated Line Output Terminals (x 2 pairs)
- Gold-Plated Subwoofer Output Terminals with Level/Frequency Control
- Variable-Color 3D Graphics Display with Contrast Control
- Motorized Slide-Out Face
CD Section
- CD Text
- Disc Name Registration
- Direct Track Access (1-12)*
- Random/Repeat Play
- Intro Scan
* Remote control only
Changer Control Section
- MP3 Control*
- CD Text*
- Direct Disc Select (1-12)**
- Intro Scan
* In conjunction with CH-X1500.
** Remote control only
Tuner Section
- 18 FM and 6 AM Presets
- Station Name Registration
- SSM (for FM)
- Seek (Up/Down)
- AFNS/PNC
- Stereo/Mono Switch (for FM)
- Auto Antenna
Amplifier Section
- Source-Specific Volume Control
- Balance/Fader Control
- Volume Attenuator
- Loudness Control
- Max. Amp Gain Switcher
Display Section
- Full-Color LED Backlight
- Switchable Dimmer
- Level Meter
General Section
- Detachable Control Panel with Carrying Case
- Multi-Function Wireless Remote Control
- Beep Tone Support
- COMPU PLAY
- Tel. Muting with CD Pause Function
- Power-Off Mode Eject
- Preferred Setting Mode
While every attempt is made to ensure the information provided on this page is accurate, specifications change from time to time and we are not liable for any omissions or errors.
Edited by Skie34
https://www.sau.com.au/forums/topic/106126-jvc-lh915/
    • Wanted to clean the film behind the triple gauge so the lights show through better.  Progress so far….
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
