i seen in the hpi
t04z hks
hks vcam
2.7 jun pistons
apparently they are making ultimate response and powerhouse with this setup..
but apparently they are still tuning the vcam..
what does this benefit as ill be running a t04z but still 2.6.. maybe getting a vcam from hks is a option to boost up the response and power output?
https://www.sau.com.au/forums/topic/106155-hks-v-cam/#findComment-1956729
Hks V-Cam:
Merit
● The intake cam of RB26DETT continual variable valve timing conversion. Private V As for CAM opening 248°. At first glance, it is moderate numerical value, but low showing the efficiency which surpasses normal lightly to revolution - high revolution with variable valve timing mechanism.
● Such as treatment easiness with the street such as surpassing acceleration on the highway and the uphill road and the time rise with the acceleration from the low-speed corner at the time of circuit travelling, with various actualizing the torque rise of very profitable concave speed situations. It locks gear position and, keeps accelerating the body very easily even to the cartridge. Improvement of torque near the supercharging standing up is the feeling like whether aerodynamic volume displacement UP it did quite of, from the especially vacuum limits.
● Because also combustion circumstance is improved by the fact that valve timing optimizes, low also environmental efficiency such as fuel economy conversion and cleanliness conversion of the exhaust improves.
● This kit typeA which can be installed easily in normal engine correspondence (the val tie variable quantitative 30°) with, expands the variable quantity by the fact that piston exchange is done and the maximum variable valve timing mechanism typeB which can utilize (the val tie variable quantitative 50°) setting 2 types.
● You can select the exhaust side camshaft due to the turbine.
Recommendation: GT-SS -> 256° and GT2530 -> 264°
https://www.sau.com.au/forums/topic/106155-hks-v-cam/#findComment-1956748
Hks V-Cam:
Merit
My Jinglish isn't so good. Sounds good though. Suprised nissan hasn't done more with cam phasing.
https://www.sau.com.au/forums/topic/106155-hks-v-cam/#findComment-1956810
whats the v-cam system worth and can i run with aftermarket 272/11.35mm cams ? finding someone in WA to set it up is the hardest part i bet.
are these available yet?
might be well worth the money if someone knows how to set it up correctly.
any ideas how it is setup? dyno tuned i suppose and similair setup to aftermarket ecu's to tune?
cheers
Brad
https://www.sau.com.au/forums/topic/106155-hks-v-cam/#findComment-1960071
if your interested to really see the difference, i will try and find my best motoring GTR specail. It shows the HKS demo r34 gtr car with it doing a LAP with the system on and off. it does make a difference to low down responds...
I know of one gtr in perth who was thinking about getting it... but i dont know if the person ended up getting it...
https://www.sau.com.au/forums/topic/106155-hks-v-cam/#findComment-1960081
http://video.google.com/videoplay?docid=-7...176590388&q=hks thats a vid of it testing it on and then turned off.
ants gtr i suppose, being the hks distributors?
https://www.sau.com.au/forums/topic/106155-hks-v-cam/#findComment-1960086
For those that are considering this, tuning the thing would be my grestest concern. Not many ECU's would do a good job with variable cams even the ones that have that feature as part of the ECU.
I would speak with a tuner that has successfully tuned an engine with variable cam timing & turbo charged and see what their thoughts are first.
Just my thoughts....
https://www.sau.com.au/forums/topic/106155-hks-v-cam/#findComment-1961438
last i herd i didnt know these were available to the public yet as i believed there were only a certain amount made at this time and they were passed out to shops to use in there demo cars and so on but if they are available already is a good thing for anyone with a big single set-up even with twin set-ups they work well though as seen in HPI on a bayside blue R34 with twin 2835R's the power curve is very nice.
Edited by zErTeK[2k]
https://www.sau.com.au/forums/topic/106155-hks-v-cam/#findComment-1962360
They are availible to the public, however they are nowhere near as aggressive cam profiles as the test units (e.g. on that R34).
As for ECU, HKS Fcon V Pro is your friend... well, as long as you can find someone to tune it :unsure:
https://www.sau.com.au/forums/topic/106155-hks-v-cam/#findComment-1962391
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
