OK guys - here's my first post in the forum, so treat me kind. I have a stock 1992 r32gts-t which has been humming along just fine for the last two years (apart from the alarm shorting out and setting some of the interior wiring on fire ... but that's another story).
Anyway, I start up the car yesterday morning and it turns over and over and does nothing. I think maybe it's fuel, so give the tank a "thud" then it finally starts - and slowly comes to life. It then coughs and splutters for the first 10 min or so. After this, it seems fine, except it still seems to cut in and out once I get on boost - like it's starving. When I stop and start during the day the same happens, then when I leave it overnight I have to revert to a "thud" to the fuel tank to wake it up. I did a search on old forum threads but couldn't find anything similar.
Given it happened so suddenly, does it sound like a fuel pump problem? If so, what's the best way to go about fixing it? I hear a factory replacement pump is around $700! Any thoughts appreciated!
https://www.sau.com.au/forums/topic/10617-r32-cutting-out/
Welcome to SAU Jedi,
If it is your fuel pump...(which is what it sounds like to me given that a thud to the tank helps!)
A GTR pump ($350-500) second-hand would be better than a GTS-t factory one especially if they charge $700 for one! The GTR pumps flow upto 450hp-500hp.
Have you replaced plugs or fuel filter lately?
Just trying to help!
Is that your skyline in your avatar? (looks real good!! I really like black R32's)
MEGA
https://www.sau.com.au/forums/topic/10617-r32-cutting-out/#findComment-170994
MEGA - thanks for the reply. I haven't done the plugs or filter for about 6 months, so probably time now. As to a second hand GTR pump - I may need help with where you'd get something like that. I'll try a trawl through the classifieds forum but other than that is there a place you'd recommend?
And yes that is my car - having looked at the pics of yours I can see why you like it! NICE GTS-4 you have there!
https://www.sau.com.au/forums/topic/10617-r32-cutting-out/#findComment-171026
I think I worded that badly. I have now 6000k's in total since I have had it. That makes it about 1500 k's a month.
It has done a couple of Can-Syd return trips, a 2 day trip checking out rural land and general get me to work stuff.
Now we have the x-trail it shouldnt do so much work. Then again I am going to Maitland Wed/Thurs so there goes another 1000ks!
RAVEN
https://www.sau.com.au/forums/topic/10617-r32-cutting-out/#findComment-171692
RAVEN
https://www.sau.com.au/forums/topic/10617-r32-cutting-out/#findComment-171717
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
