Howdee everyone,
My aircon clutch keeps blowing the fuses. I'm not sure why either. It might be that too small a fuse is installed. I have no idea what the correct size fuse is for the clutch...?
Also, it would appear that some amater auto elecky has been messing with the system because the relay that normally fires the clutch isn't firing either.
I have tested the relay, no problems.
I have tested the clutch by hard wiring it to power, no problems, but it does draw some pretty heavy current. Probably about 12 amps at a guess.
I have measured power at the relay box on the relay coil side and its ok, but when the aircon switches on, the computer/climate control or whatever that switches the relay isn't turning on the relay. The volts on the -ve side of the relay coil don't drop to 0v, so the relay doesn't switch.
Is it the factory EFI ECU that controls the aircon, or is it the climate control box that directly fires the relay..?
Cheers,
Ian
That was the first thing I checked... its definatly the air con clutch drawing too much current blowing the air con clutch fuse. And the signal that comes from the ECU to control the compressor appears to be rooted.
I'm going to test fire the relay from under the dash on the ecu signal out cable tonight. If the relay works then it means the output on the factory ecu has been blown up. No big deal though because ill be controlling the aircon compressor from the Wolf ecu soon.
  • 1 month later...
Here is a guide for removing the windings from the aircon clutch so they can be replaced/rewound:
http://www.skylinesaustralia.com/forums/in...howtopic=112597
Sorry should have posted back on this... Problem solved...
It turned out to be the clutch. I bought a whole compressor off ebay for $150, and after much bitching and moaning managed to replace the clutch without removing the compressor from the car. Over an hour on one circlip! But after a re-gas it all started working fine.
10 Amp fuse and she's fine.
I was told by the aircon guy that this can be a common thing... Don't know nor care about it now tho cause i'm chillin' out in my skyline now!
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
