Item: 1993 R32 GTR. Burgundy. 76200K's
Item Condition:Excellent
Reason for Selling:Selling to buy another car
Price and Payment Conditions:$25,000
Contact Details:Karl - 0422 32 39 37
Extra Info:Followed tutorial on uploading photos but only "X" shows up and not the photo so please follow link to carsales and carpoint for more pics:
http://www.carsales.com.au/pls/carsales/...rch_distance=25
and:
http://www.carpoint.com.au/used-car/NISSAN...nd/1161239.aspx
Immaculate car in top mechanical condition. Serviced every 5000klm at Chapman and Chapman in Brisbane. Speak to Andrew Chapman if you want to know more about this car...he knows because he chose the car for me after seeing/test driving/checking out quite a few cars. Car is factory fitted with rare and expensive options like genuine Nismo front seats and genuine Nismo sports exhaust (standard dumps, nismo front pipe and nismo cat back). Recent new additions is genuine Nismo full floor mat set (5 piece and still have old floor mats). I am the first Australian owner with the major service done by Andrew Chapman upon receiving ownership of the vehicle that included changing all fluids, and replacing the timing belt, etc - everything that needed to be done for the 100,000K service.
This car is as close to stock standard as they come with an integrated turbo timer to the 3 point immobilizer alarm. Interior is very neat and tidy, no melted dash, no broken air vents, no peeling trims, etc. commonly seen on a lot of other skylines. Has an Alpine single CD/MP3 player, upgraded speakers, and an amplifier. Car drives and feels tight with an engine that pulls strong and cleanly along with new tyres that were fitted less than 1000klms ago. If you want a GTR that's most certainly one of the best examples around, this is it.
Current rego will expire in March but will include 6mths rego.
Sorry, not interested in trading as i already have a second run around car.
Call me for more info and/or organise a time for inspection
Edited by poop
https://www.sau.com.au/forums/topic/106209-fs-1993-r32-gtr-burgundy/
Upload pics to the SAU database underneath the text window in 'edit post'. Your first link to carsales is dead...
I bought my car from a Karl too. Very nice car and with stock air intake too, don't hardly see that anymore.
Good luck with the sale.
Thanks for telling me about the dead link, it's all fixed now. will try and upload pics again...
Edited by poop
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
