Hello,
I currently own a silvia, but was thinking about buying an 4 door R32 skyline with the intention of doing an rb25det conversion (i have my reasons for going after the 4 door version too). I am familiar with converting silvias to rb20, as i have done one conversion before with a mate, and am hoping that this conversion is close to the same complexity (hopefully easier!). :D
(incase people are anything like they are on ns.com, yes i have searched already!)
What i would like to know is the following:
1. Is the engine a straight drop onto the r32 cross-member or is the r33 cross-member utilised or do people just customise the mounts?
2. Drive shaft and lsd - is it possible to re-use the r32 drive shaft with the rb25 gearbox or are they different lengths, different yokes etc....?
3. Do brakes need to be upgraded in order for the car to pass engineering and be road worthy (in NSW)?
4. Any dramas with power-steering lines or pumps etc...? (not to concerned with the a/c)
5. Are there any other dramas that i have missed or that i should know about... i.e. im guessing the rb20 dump pipe wont be able to be re-used etc...?
Thanks for your help in advance,
Lucius.
Edited by Lucius
https://www.sau.com.au/forums/topic/106222-r32-engine-conversion/
Do another search, seriously there's a 25 into 32 post atleast once a month. But seeing as it's a friday and i'm bored at work:
1) Use the rb20 engine mounts on the rb25 with rb20 crossmember
2) R32 driveshaft can be used but needs to be shortened and a new yoke and uni's installed to fit up to the 25 box
3) A brake upgrade is a good idea as the 33 has bigger brakes. rears are the same.
4) Use the r32 power steering pump and bracket to avoid hassles with the lines
5) Yes. (search :D) rb20 dump fits.
did i mention search? There's a bit more to it than you think, but it's not particularly difficult. Wiring is the fun one.
*r32 crossmember should be fine as are used to put both rb20's and rb25's in s13's
*tail shaft will be a different length, as the rb20 and rb25 gearboxes are different lengths.
* dont see a problem with using the rb20 dump pipe as the turbo/dump flanges are the same on rb20 and rb25
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
