  • Replies 286
Ok yes Daniel thats what i have done, just bolted the top 4 up, motor is in, what a nitemare with the cv's etc :D, little bit of an issue with the bonnet clearance tends to hit, so i not sure either bonnet scoop or ill try adjusting it to suit. Tomorrow ill be getting my custom dump pipe installed then ill hook the gt3540 up :(. Funny thing is it looks just like an rb20 especially with the rb20 cover, i think some ppl are going to get a shock!!! Who else in SA has done this mod to 4wd???
Edited by FOOLBOOST
in sa i think you will be the first I dont think i have sold any to sa, and i havent heard of anyone having done it to 4wd. The issue with bonnet clearence isnt an issue with GTRS as much due to the rb26 head. The cv can be time consuming but if you did it again you could do it in half the time, its all about experience and practice. Sounds like you hookin in though good to see!!!
Ok yes Daniel thats what i have done, just bolted the top 4 up, motor is in, what a nitemare with the cv's etc :thumbsup:, little bit of an issue with the bonnet clearance tends to hit, so i not sure either bonnet scoop or ill try adjusting it to suit. Tomorrow ill be getting my custom dump pipe installed then ill hook the gt3540 up ;). Funny thing is it looks just like an rb20 especially with the rb20 cover, i think some ppl are going to get a shock!!! Who else in SA has done this mod to 4wd???
Sound like your getting closer to start-up. Im getting closer to starting my conversion.
RB30det Should be a good thing in a 4wd, after having my 300rwkw RB30 in a 2WD r32 for near 2 years, i cant wait to convert to 4WD and make use of some of the massive torque and power the RB30 has to offer.
I have heard of GTRS with 230+rwkw doing cranks in on hard launches due to oil all going towards rear of sump, what is the best way to combat this??? With my sump when i modified the oil pickup i put it right towards the back of the sump front buldge and as low as possible for maximium pickup, hope i dont do a crank in.
its all rubbish from poorly informed people.
There is no such problem at all
have a read
http://www.skylinesaustralia.com/forums/in...howtopic=110680
  • 3 weeks later...
Have any of the guys who have done this conversion come across a problem where the bottom bell housing bolts dont line up with the holes in the bottom of the sump due to the adapter plate? I saw this on another forum where the guy made his on plate
I am going to be putting my RB26/30 engine into my gtr soon and would like to know if this is an issue
Nathan
Nathan
Yes, what we did with mine was to attach the gearbox to the block and re-drill into the sump extension, either that or just bolt up the top bolts dont worry about the bottom ones :(
Yes, what we did with mine was to attach the gearbox to the block and re-drill into the sump extension, either that or just bolt up the top bolts dont worry about the bottom ones :P
So were exactly did you drill the holes into for the bottom gearbox mounts?
All you have to do is bolt your gearbox on then drill through in the sump extension, the bottom 4 bolt holes this will make new bolt holes for the bottom 4 then stick a thread in them and your :). We used the vl gearbox which we figured out is different to the Gtr one after as the bolt holes didnt line up, doesnt matter if it comes to it just bolt the top ones up, dont worry about the bottom ones :) .
Edited by FOOLBOOST
  • 1 month later...
Guys, hope the conversions are going well, please let us know how you're getting on. What issues have you found that are created by the extra deck height? Dump pipe length springs to mind as a 'must do' but what else - 38mm is enough to interefere with a/c lines, ps pump lines, rad hoses, harnesses, earth straps etc. Would be great to know how you've overcome these.
Regards
Regards
a/c lines = not a problem, the A/C compressor is in the same place
ps pump lines = not a problem, the power steering pump is in the same place
rad hoses = not a problem, the standard hoses fit just fine
harnesses = the engine harness actually goes downwards on a RB26, so they actually fit better on the RB30
earth straps = not a problem, they bolt to the block in the same places. The only different one is the exhaust manifold to LHS inner guard. But I always use a larger capacity cable anyway, so no big deal. Plus you have to change it if you change the exhaust manifolds.
:P cheers :mad:
Edited by Sydneykid
so with a 26/30 TT config engine using all of the standard bolt on parts I need to do nothing different to a normal RB26 engine r and r except lengthen the dumps and the above mentioned earth strap, and tune? i guess fmc plumbing too..but that's ALL?
No change to the intercooler plumbing either. But I used silicone joiners, maybe they were a little longer.
As previously mentioned, you will have to redrill the lower bell housing bolts, but that's a 5 minute job.
I didn't lengthen the dumps either, but they weren't standard ones.
I upgraded the sump (Performance Metalcraft) for GTR oil surge prevention.
Plus added an oil cooler, of course.
I also extended ther lower cam cover, so it met up with the standard RB26 top cover (keeps the rocks out)
:ermm: cheers :D
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
