  • Replies 286
thanks for the heads up on the plate, ( proengins)
well had a go at making a wedge, first attempt nearly lost my finger, with the grinder.
but got there in the end, god 2mm one side 10mm the other side then drill out the center to fit over the thread.
but all on now and straight, all gaps the same to water pump studs 4mm, so well chuffed.
piccy
you cant use any other engine mount dave, because as it is there's 2 parts of fook all clearance between the bottom of the diff and the cross member. i posted a pic in here somewhere showing how close it sits
  T04GTR said:
so, rd28 engine mounts solve the bonnet clearance issue? or is there something else? ive tried reading it all but no definative answer.
if u are enquiring about an rb30 in a gtr, u need to use the same mounts. u can slot the mount holes but not recommended due to lack of clearance
  • 3 weeks later...
  unique1 said:
lol i gain an extra 200kg (stagea) over a gtr but my bonnet shuts without an issue with covers on and twin turbo pipe on :D I'd still rather lose 200kg and need less power lol.
I have been thinking about running twin gtrs turbos now instead of -5s, i think they are -10s from memory? I remember someone on here runs them on a 30 setup and wondering what the drivability is like? i want around 500hp at wheels mark on 18-20psi. Im running a freshened bottom end but still stock rods and duratech cast pistons, so still around the 8:1 comp ratio. I dont care if the thing blows to bits i wanna see how long it will last :down: My head is stock 26 with no port work and stock cams at the moment which wont help either, but bolt in cams are always a future option.
Ive got GTRS's, i want to swap them for dash 5's in the next month or so.
What rear does your set have?
Drivability is pretty much perfect as Marko said. Only things id change are turbos and cams
  T04GTR said:
ok cool. just gotta figure out how im going to fit my s372r borg warner turbo in there...
Harden up mate, iraqi sand dune nissan patrol racer style right out the bonnet level with the roofline :laugh:
  • 1 month later...
Maybe someone get shed some light on my current set-up and the issues I am having...
Im running a built RB30 bottom end with standard 25 vct head. The old set-up was running a GT3082r (0.82r) with 6 boost and supporting mods and made 280rwkw @ 17psi. This is through a built 5speed auto, fully manualised with 4500rpm stall.
I then changed to a GT35R with the same mods. On 11psi, the car made 246rwkw @ 7100rpm. We then upped the boost to 18psi, however the car only went 260rwkw and stopped making power after 6000rpm (sharply).
Any ideas what this could be? A few people have mentioned valve float but I also dont know how to verify this.
  bubba said:
What size rear housing on the 35R and what size exhaust? cat? sounds like a restriction..
.82r ... its the exact same housing as the older 30R but just machined out to fit the larger exhaust wheel. No cat, just a muffle towards the end of the system (being a 3" mandrel).
  • 2 months later...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
