I have also read that if you deck the block then 25/26 pistons work well .... is this true ??
What comp ratio do you roughly end up with when using RB25det pistons ?
Cubes and i are using Wiseco rb25det pistons in our rb30det. They decked the block (20 thou?), and added a 3 layer metal head gasket, and compression works out to around 9:1 if Cubes' calculations are spot on :)
Oil squirters are overrated. Do like SK says, ceramic coat the pistons etc if you run cast ones, or just run forgies and dont worry about it :)
Having a piston sit down in the bore is dodgy, because its supposed to end its stroke flush with the top of the block. Otherwise compression, squish etc are all off.
No one has mentioned about the rb26 head having larger head studs that the rb25. You need to retap the rb30 block out to bolt the rb26 head on.
  • Replies 286
I am still wondering about the SUMP adaptor, cant u just use the sump from the GTR/GTS4 on the rb30? U might have to modify it a little? Also is it ok to use a VL turbo headgasket with the 25de head? If not will an rb25det metal headgasket do the job?
The bottom of a RB 2wd block looks nothing like the bottom of an RB 4wd block. The 4wd block is much wider, has many more and much larger diameter bolt holes. As you would expect to hold up a big diff, drive shafts and large cv joints for the front drive.
:P cheers :P
Yes well i am a noob to this, so feel free to drill me all you like :P . Well if a sump adaptor has to be used then ill have to get one, the guy that sells these on the forum does he answer his pms? Its just i hope to have my motor finished by sunday and hence ill need the adaptor before i can put it in next week so id like to get it kind of soonish... Also how many are going with a custom plenum to solve plenum hitting bonnet problems? If you do modify the engine mounts to suit then wont the gearbox and everything else be out and be under a lot of stress, hence why i am just getting a custom plenum top $200 bucks let me know if anyone else needs one.
Sorry to ramble so much in the one post but i have a few more questions :P . Which turbo would be ideal for this motor Gt3540, injectors GTR 440's, Q45 TB and Q45 AFM? At the moment i have a HKSGT2510 which would make it more like a supercharged 25/30 :lol:
Edited by FOOLBOOST
ok, well i'll point out if you are doing the rb26/30 conversion, you would be using the rb26dett head, which already has the front facing plenum from factory.
gearbox etc, can be spaced down the same amount the engine is dropped, but ive been running my car without doing it with no vibrations, or problems.
Turbo, i suggest whatever power you wish to strive for with the supported mods. Gt2835r or upwards (gt30r minimum), and a longer diff ratio.
25/10 is way too small like my turbo. On boost its useless, just wheelspin.
The castings are slightly different, the oil gallery that the squirters have to be tapped into has variances in its diameter and the wall thickness varies as a result. I have found no common ground
Thanks SK, mystery resolved.
no I am not pullng it out of the car to take photos
lol ..... and why not ??? no help internet people of today :lol:
Cheers black32
I am suprised it works out so high comp wise as the extra CC in the head drops the comp a bit from what i understand.
Just to confirm you decked the block for the sole purpose that the pistons sit to low ? and not to gain comp ratio ?
Cheers black32
Cubes is the details man, more of a memory than i :D
Bit of iffy area about what our comp ratio works out to be, as the engine builder worked it out to around 8.5:1, but cubes says he worked it out to be 9:1. And going by somethings (like the amount of timing we run ?) he seems to think it may just be.
Hi all,
My adapter plate allows you to bolt the rb26 sump to the rb30 block. It is CAD designed to match the rb30 block to the wider 4wd sump. However there are other mods that have to be done besides just the adapter.
After that you will have to fabricate an external oil pickup due to the different pickup locations for a rwd rb series engine and a 4wd engine. You will also need to lastly modify the studs on the cv side of the sump to 2 long bolts, and also die grind or mill flat a part of the rb30 block to allow bolts instead of the studs on the diff side. This all sounds hard but i provide detailed instructions on how i did it and how you can do it, and if you are mechanical you can do alot yourself, I have done around 6 know and have sold many plates. This aside i sell the bare plates laser cut from cadium plated mild steel for $450, and if you got the rest done at a workshop it would cost no more that $4-600 in labour. So total cost is around the 1-1.2g mark, which is very competative considering RIPS will not do the job without selling you a built bottom end for $3800, and NIZPRO and AVO will not do it with out your own motor and sump sent to them and they charge $4200, theres is slightly different but I also offer different versions of tha adapter, however I am not bagging these workshops they do good work, but if you are a DIY'er then my setup is perfect for saving some money and getting involved.
If you have anymore questions please dont be afraid to ask. But i don't really want to give out pics and detailed instructions just yet when it took me so many r and d hours to work it out for myself, like i said the other guys that do the conversions wont even sell the plate seperate cause they dont want to give away secrets!!! But like i said if you have questions about the process of fitment please dont hesitate. The plate i sell is straight forword and guys out there could make one themselves but it takes time to get spot on, and most people would rather buy soemthing they know has worked ad yeah I am not in this to make money so i basically sell the plates for what they cost me.
Cheers,
Daniel
Oh and FOOLBOOST if you want to chat give me a call on 0418 327 427, not on the computer much anymore so dont get to check my pm's.
Guys i have now got a problem cant find an r32RB25de non vtec head, so looks like i will be going rb26 this will also solve the bonnet/plenum clearance issues. Was wondering what mods have to be done to the stud holes with regards to being smaller? Also will it be a nitemare to setup the inlet plenum throttle linkages and wiring to go to the rb26head? I am also thinking of going single turbo if i can get a single turbo manifold or is twins better would be much easier since id be getting the twin manifolds with the head anyway???
Have located an rb26 head with plenum and exhaust manifolds complete 1500 apart from injectors, cas and ignitor. Now can i just bolt on an r32rb26 head with mods to the bolt holes and use my gts4 injectors, cas and ignitor and power fc??? Then i will have to locate twin turbos or run a single if i can find a single turbo manifold!!
Ended up getting a complete r32rb25de non vvt head with injectors coil packs, manifolds etc $500. Have finished bottom end pistons and crank, just waiting on metal headgasket and head goes on. I have also just received one of daniels sump adaptors nice piece of work! Now all i will be left to do next is modify the bottom end to suit the 4wd and relocate the oil pickup etc does anyone sell these already done??
Edited by FOOLBOOST
Heads on, ran into the problem of the exhaust manifold touching the block, so have decided to grind the manifold down rather then the block. Also just bought a GT3540 with 1.06 rear AR hope thats not too big or i will be changing to .82 soon if its too laggy. Will be making a custom adaptor plate to standard manifold which runs an external wastegate along with custom dump pipe, ill post some pics up.
  • 3 weeks later...
My 25/30 motor is finally finished and there seems to be one thing i have overlooked, it says to grind down the webbing in the sump on the rb26 sump, since i am using a 10mm sump adptor plate will i still need to grind the webbing down?? I need to know asap as the whole motor is finished and i want to make sure the rods arent gonna hit on the bottom of the sump??
Edited by FOOLBOOST
i just got my RB26/30 engine back from my engine builder and was wondering what people do for oil and water feeds for turbo's, i am using a high mount twin setup if that makes a difference
rb20/25 sumps have webbing towards the rear of the them which has to be grinded down otherwise rod cap will hit, rb26 sumps dont have webbing so dont have this problem! What the hell do i do with the gearbox since the top 4 bolts line up but the bottom 4 dont any ideas??? Thinking of just using the top 4 and leaving the bottom ones out :D:laugh:
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
