Hi all :) ,
Just wondering if anyone else has experienced this.
We still have the standard radio and cd player in our car :P and it doe's a rather strange thing.
I was mucking around with the radio one day and came across a channel that actually shocked me that I could get. :P
When the radio is set at a certain frequency we can pick up the police radio channel.
Has anyone else experienced this?
is this a complaint? lol i'll swap ya :P
what frequency is it set to exactally? i've seen japanese radios that have weirded out freq settings....like our JJJ in bris is 107.7, on the jap radio it would be like 98 or something rediculous (this is just an example, i know the gold coast is 97.7 :P)
hell no..
no complaints here.
comes in quite handy actually. :P
not out near the car at the moment but from memory its 78.3 fm or somthing close to that.
The reason for this is japanese radios have a different frequency range than australian radios. you;ll have an adapter in series with your radio boosting the frequency of all chanels by 10 or 20Mhz, so if in Aus the station is 102.5, on your radio it will read 82.5, or if the staion is 94.6, the radio will read 84.6 or 74.6, i forget how it works sometimes. but basically it's out by a factor of either 10 or 20MHz because of this converter.
cool, so do your normal radio station freq's match up? it must be an australian standard/regulation or whatever you wanna call it, that our radios can only cover such a range (somethin like 88-108 or close to it)
consider urself special :P
edit: just noted ur reply terminal..i knew there was an easy explanation :P
Edited by timmmay
Mine's set for JJJ as well, the frequency for Sydney is 105.7, but the radio says 87.7.
I'm hanging to get rid of mine. The radio doesn't tune properly (the reception is crap on mine, so I'm guessing the frequeny band expander is a cheap one), I've blown two speakers in it because it's not loud OR clear enough, and the CD player jumps over even minor bumps. :(
I'm saving some money to get some new speakers and an amp, buy a single-DIN unit so I can put some gauges underneath it, and maybe get a sub in a super-small enclosure (as small as I can get away with) so it doesn't take too much room in the boot.
reception would be crap because of the booster not set up properly. i used ot get crap reception, lose tripleJ about 20km from canberra. when i got the radio place to fix another problem they noticed it wasn't hooked up right and now i can get it anywhere they transmit. even in the middle of nowhere.
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
