Hey guys.
My car (S1 R33 Gts-t) is currently running the following.
ITS460 (460hp internally gated T04e)
Wolf3dv4
FMIC
Fuel Pump
Malpassi FPR
3inch zorst all the way
I've been advised to leave it at 16psi due to the injectors maxing out and have managed about 230rwkw from this setup with according to the tuner (P.I.T.S), plenty left in the turbo.
So I'm going to do my injectors shortly. 550cc Nismos or something similar. This will allow me to run 18-20psi boost which will mean I'll be getting the best out of my turbo rather than running it under it's efficiency level as is at the moment. The power curve climbs and climbs and then drops as soon at it hits the rev limiter.
Now as this is going to require a retune, I thought that I might as get get some aftermarket cams installed at the same time. I'd really want more power and torque through the midrange where it's lacking at the moment and the faster spool times as well as higher boost should keep me content.
From what I've read and searched here, the way to go is the Tomei Poncams as they directly replace the stock cams without further modifications. I've also read that on an RB25 the timing works best at 0 degress meaning I won't need to purchase adjustable cam gear.
After this, I'm going to stop mods completely.
Does this sound like a suitable idea? Will I benefit from having the cams installed considering my current setup?
Thanks for any advice or hints.
https://www.sau.com.au/forums/topic/106239-cam-advice/
