1990 R32 GTR - GENIUNE NISMO EDITION
ORIGINAL CONDITION, TRUST INTERCOOLER, HKS PIPES, MINES POD FILTERS. TWIN PLATE CLUTCH
EASY CAR TO DRIVE AND FAST. $20,000ono WITH QLD SAFETY CERT AND I WILL INCLUDE 6 MONTHS QLD REGO OR "AS IS" UNREGISTERED/UNCOMPLIANCED FOR $17500
CAR IS IN GOOD MECHANICAL CONDITION AND BODY IS TIDY FOR ITS AGE.
Information about the Nismo release.
FEB 1990 - Nissan announced the release of the limited edition Skyline GT-R Nismo with the purpose of participating in the JTC Group A (Japan Touringcar Championship ). Engine durability and reliability have been improved by adopting the metal TO4B turbine instead of the ceramic TO3 turbine. The Skyline GT-R Nismo is equipped with a front bumper with air intake, a hood top mold, a small rear spoiler under its stock rear spoiler, and Nismo stickers. ABS, air conditioner, audio, and rear wiper have been removed to reduce weight.
The car is as described above except it has a stereo, and aircon fitted. I dont know if it has TO4B turbos but it should have.
HISTORY OF THE R32 GTR (BNR32) THIS HAS BEEN TRANSLATED FROM JAPANESE SO INCLUDE SOME TRANSLATION ERRORS. I HAVE HIGHLIGHTED IN RED INFOMATION RELATING TO THIS MODEL NISMO. THIS NISMO IN NUMBER 394 OF THE 560 MADE.
Gross production quantity
43,934 units
Production quantity classified by type 40,390 control vehicles
NISMO 560 unit
V specifications 1,453 unit
V specifications II 1,303 units
228 N1 based specifications
Under carriage number division GT - R NISMO (marketing quantity 500 units)
Under carriage number 100000 - 100560
Prior-term type: 1989 August 21st -
Under carriage number 000051 - 017466
Mid-term type: 1991 August 20th -
Under carriage number 212001 -
Latter-term type: 1993 January -
Under carriage number 300001 - 314649
Register quantity of classified by year type 1989 system (1989) 4,555 units
1990 system (1990) 8,426 units
1991 system (1991) 7,081 units
1992 system (1992) 7,961 units
1993 system (1993) 6,204 units
1994 system (1994) 7,465 units
Standard setting body color Prior-term type
Gang ray metallic (KH2)
Jet silver metallic (KG1)
Dark blue pearl (TH1)
Lead pearl metallic (AH3)
Black pearl metallic (732)
Mid-term type/latter-term type
Crystal white (326)
Spark silver metallic (KL0)
Prior-term type 1989.8.21 Debut at that time price: 445 ten thousand
It comes after ƒnƒRƒXƒJ and ƒPƒ“ƒ?ƒŠ and it debuts the victory of group A as a purpose as 3rd generation GT-R
Total length 4,545mm?~ full 1,755mm?~ total height 1,340mm wheel base 2,615mm
Vehicle weight 1,430kg
The highest output 280ps/6,800rpm largest torque 36.0kg-m/4,400rpm
Engine type RB26DETT total cubic displacement 2,568cc
* Adoption of twin ceramic turbocharger
* Electronic control torque split 4WD (ATTESA E-TS) adoption
Adoption of *4 wheel multi-link suspension
Adoption of *225/50-16 inch tire
ƒjƒXƒ‚ 1989.3.11 Sale at that time price: 441 ten thousand
560 units were produced as a Gr-A evolution model.
* Turbine wheel material of turbocharger from ceramics modification to metal
* Adding the air intake to the front bumper
* Addition of hood top mall
* Modification of side sill protector
* Addition of small-sized rear spoiler
* Abolition of rear wiper
The abolition of *ABS
* Abolition of air conditioner
Abolition of *I/C grille
* Vehicle weight 1,400kg (the light weight conversion of 30kg)
Mid-term type 1991.8.20 Sale at that time price: 451 ten thousand
* Addition of side impact door beam
* Driver's seat SRS air back option setting
* Addition of seat belt warning light
* Adoption of shocking absorption steering wheel pad
* Adoption of interior resistance to flame conversion material
* Modification of headlight lens and H1 conversion of valve
* Vehicle weight 1,480kg (the increase of 50kg)
Latter-term type 1993.2.3 Sale at that time price: 454.5 ten thousand
* Clutch structure from push system modification to pulling system
Modifying rear diff. cover form from the *94 model
V specifications 1993.2.3 Sale at that time price: 526 ten thousand
Commemorating Gr-A3 year successive victories, it sells
* Total height +15 it makes 1,355mm
* ƒuƒŒƒ“ƒ{ corporation make brake caliper - and adoption of rotor
Adoption of *BBS aluminum wheel
Tire adoption of *225/50-17 size
* Vehicle weight 1,500kg (the increase of 20kg)
V specifications II 1994.2.14 Sale at that time price: 529 ten thousand
Commemorating Gr-A4 year successive victories, it sells
Tire modification to *245/45-17 size
* Adoption of private sticker
N1 At that time price: Control vehicle based 430.5 ten thousand V ƒXƒy?[ƒbƒNƒx?[ƒX 509 ten thousand
V specifications II base 512 ten thousand
It sells as the pace vehicle for N1 durable race/lace participation
* Adding the baffle plate for brake cooling
* Headlight from projector system modification to suspicious looking 2 light systems
Also the based vehicle respectively simultaneously with *V specifications ¤ V specifications II sale modification
From *V specifications base turbine wheel material of turbocharger from ceramics modification to metal
Thanks for looking
Edited by XJ40
  • 3 weeks later...
It was an investment being a Nismo.. I would comply the GTR, but if the buyer is from a state other then nsw/qld it would be a waste of money as rules are diffrent. It only takes 2 days to comply so its not a big deal..........
Edited by XJ40
  • 3 weeks later...
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
