The car was tuned correctly when it first was built (when it did alot of km's as well being a daily driver then). The problem crept up when I added on parts that would alter the AFR's and never got it retuned properly, just patch up jobs here and there, and as an end result it ran stupidly rich on boost. The AFR's on boost were low 11's, and for one small part of the map dipped into the high 10's. Aside from that, cruise was never worse than 14.0:1. Im going to stop being a slacker and get it properly tuned (map wiped and start from scratch) when its back together.
Ferni, dont run octane booster, it does the same thing :unsure:
Edited by Amaru
Slightly off topic, but does water injection help to keep pistons clean?
I know in an old engine that I blew a head gasket on years ago, the one cylinder where water entered had a very clean piston, whereas the others were all carboned.
Yeah if your careful, you can suck small amount of water in with manifold vacuum (use a few revs for a while) and it will clean the pistons more then you would think it would.
Otherwise get something like suburu upper cylinder cleaner, designed specifically for this purpose (highly recommended by many people) and works better then water alone.
  • 4 months later...
old topic, I know.
When you pull an engine down, the condition of the bore can not be determined by hone marks. Its a common misconception!
The way manufacturers hone their engines, you will see hone marks at over 200,000klm. Im sure some people with that sort of mileage will strongly agree.
The only way to determine the condition of the bore is by measuring it at several different levels as this give you a much better idea of the distortion of the bore. You will often find more wear in the middle of the bore then at the top 1/4 and bottom 1/4. Not only wear but distortion where the bore is oval- this leaks compression as the piston powers through the combustion phase and as it reaches Bottom of the bore.
On some of the better engines, you will often find that bores are machined, honed and measured with a dummy head fitted to account for block distortion when the head is torqued up. Its mainly used on more serious engines as the results of a few thou and insignificant on a road engine.
Lastly, excessive carbon on the top of the piston is unlikely to cause pre ignition on boost. If your mixtures are consistently running that rich on boost- The amount of fuel that the engine is seeing keeps the combustion temps low enough so that the carbon wont cause pre ignition. Im not saying that it is good to run AFR's this rich, im just saying it is safer. I personally would rather run 11.5 AFR on boost then 12:1 on a track day. Yes, the leaner mixture will make up for some power, maybe 5% difference at this level but at 11.5 the engine will run cooler, combustion will be cooler and there is less chance of melting engine internals when your running full throttle for 10-15 min stints 5-6 times in a day.IMO I would rather drop 5% power but be sure to drive the car home.
hmmmm the run in should be done on a dyno and do NOT baby it... 50km on mineral run in oil at 5-7k revs loading it up!
just warm the oil up to the 90c mark with a warm up idle and roll on the dyno first....
drop the oil after the 50km on the dyno, and then repeat with semi syn. oil for another 50km medium to high revs/ load....
then your top wack oil i.e 300v or castrol 10w/60
no more run in required and will have an engine with more power and long life!
yes Im sure there will be controversy over this but it is true :blink:
yes Im sure there will be C over this but it is true :dry:
I'm with you on this one maybe not right up to 7k at first though. I usually put 20kw load on and accellerate through to 3/4 of the rev limter max and then decel, then reapeat about 5 times and then double the load and do the same thing and then double the load again. If you engine isn't run in, in the first 500k's then it will probably never be run in. I'm sure this will get some controversy as well!!!
Edited by rob82
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
