hey guys, Ive upgraded a few things on my car so im selling a couple parts i got collecting dust in the garage.
R33 S1 front bar, good condition, minor dints on the bottom of the bar due to a few scrapes here and there, but no scratches on the actualy paint or anything.
Looking for around the $190 mark
R33 s1 grill $50 -
R33 s1 standard intercooler $100
Located in Mill park/South Morang melb
Contact George 0431252453
https://www.sau.com.au/forums/topic/106316-r33-parts/
pics of front bar ? or at least what colour and if it's type m?
the gunmetal grey colour they come in, nah not a type m, just the original series 1, the first ones that were realsed. its of a 93 .
https://www.sau.com.au/forums/topic/106316-r33-parts/#findComment-1963870
  • 1 year later...
interested in the front bar and cooler, i have a s2 is htere any difference in the pices other than what they look like, will they line up the same??
cheers simon
R33 s1 grill $50 -
https://www.sau.com.au/forums/topic/106316-r33-parts/#findComment-3507542
