Hi. I am contemplating buying an R33 RB25DET PowerFC for use on a R33. For the time being, the PowerFC will be tuned to run an RB25DET with stock turbo. However in the near future, I plan to put in an RB30DET running an R32 RB25DE head without VVT. Will the R33 PowerFC still run this fine (not having VVT)? I will use all R33 RB25DET sensors.
Also, what kind of injectors does the RB25DE (R32) head use? Are they top feed or side feed?
Thanks in advance!
https://www.sau.com.au/forums/topic/106333-r33-powerfc-on-rb30det-non-vvt/
you will need to use the R33 RB25DET loom, and all the sensors should then plug in. the lack of VVT will not be a problem at all. mine isn't plugged in at all. your tune might need some patching up though, due to the camshaft timing not changing any more.
Seriously consider keeping the VCT unless you are going to go massive cams. If you are looking at massive cams go the rb26 head.
The R32 RB25 head really is only a good option for the R32 as it allows a stock look without modification of wiring/sensors or injector types.
The R32 heads are fairly rare these days, I've only seen R33 Rb25de heads at the wreckers lately.
Besides the point the R33 rb25 head is slightly better (has slightly larger ports and better designed plenum) than the R32 rb25. Only slight.
In the real world it appears to make no difference to power outputs.
The VCT however does. Definitely worth keeping the VCT.
The R32 RB25 head does bolt up without mods.
BUT... The VCT isn't a LOT more work, its very minimal.
Don't worry about it just dive in and do it. There's plenty of information around on how to do it. Measure the rb25det vct oil restrictor and be sure to place one in the feed to the vct from the pressure sender.
The point is... You will find plugs and connections to be different with the r32 rb25de head, not to mention different injectors, throttle body etc..
Its more work doing that than having your engine builder block off the vct oil supply drill and tap a new one.
Yeh, I have pretty much gone through all of the pages in that thread. Along with reading the PDF guide. Very informative, and great work. However, if I use the RB25DE head from the R33, won't that also mean the head will need to be welded to seal the water galley on the RB30 block, along with blocking off VCT oil supply, tapping new one, etc.. As opposed to just putting the current R33 RB25DET sensors in the R32 head. Just seems easier.
Hmm. Now I don't know which path to take. I guess I'll see what head is available for what price. How much would it cost (approximately), to modify the R33 head, with regards to VCT oil supply? Thanks for the feedback guys!
Well I did get the whole engine built there, but really - to hook it up, you just need to drill and tap a fitting at the front of the head into the oil gallery, get a piece of braided hose and some fittings.
Just put a t-piece onto the oil pressure sender for it to hook into. :(
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
    • Turn up your speakers https://youtu.be/5_GK5ChNjOs?feature=shared
