ok a few things...
for one i need to use the remote to unlock doors but then need to use a second remote to disarm the immobiliser and vice versa when leaving the car. i want to be able to do it all with one remote.
also the alarm arms after about 30 seconds after unlocking and disarming if you dont put the keys in the ignition and that sets off the motion detectors... not gonna be good when putting a sleeping baby in the back.
plus i wanna get the frequency expander tuner thing to pick up australian radio band.
and thirdly i wanna get someone to see if they can hook up a TV tuner so we can pick up tv channels... getting the audio from them now but only a snow screen on the monitor
hmm i know of a place on Hassall St, Wetherill Park but not sure on what the business is called. They do custom alarms and custom stereo installations so they may be able to help you out with the tv situation. I know it's in the middle of the street and Hassall St is about 300 mteres long.
They did my alarm and installed my tv/dvd.
I know the owners name is Ken.
Edited by ed R34
Incar Option...
The motorsports side did my full turbo upgrade. But their head mechanic that did all the engine work on my car has since gone back to NZ :unsure:. He was good. The new guy there? I dunno.. haven't met him.
Ken Ouy is the owner of Incar Option. He knows me well.
He did the alarm in my dad's brand new S2k, my previous car (integra), my Skyline, and my g/f's Skyline.
He also organised and sourced all the parts for my turbo upgrade too. Ken's great.
But I think he may be a bit busy at the moment.
Unit 5-6/64 Hassall Street
Wetherill Park NSW 2164 Australia
ph: 9609 1122
Ask for Ken. He'll know whether they can do what you want.
The premises do look a bit dirty, but they're in the process of fixing things up I think.
for the TV go to nams. nams electrical listed in yellow pages i think. you most probably need a new tuner circuit and maybe a pal-ntsc converter. nam will know what to do anyway.
other than that lifestyle in parramatta did my last stereo install, they were not too bad.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
    • Can you covert an R32's AC from r12 to r134 if the compressor/hoses etc are still all good? Pretty sure on my car the AC was degassed when it was imported  to remove the naughty r12 and save the ozone layer, and the fancy climate control system just blew air around. Was happy to drive the car with windows down back then, but now I am old and need to be kept cool
    • Just to circle back here, I've sold my automatic trans to another Stagea owner in OH.
