hey guys im about to crank the old 26 over for the first time in the next few days to get initial oil pressure before we actually start it.
i had trouble last time when my motor had no oil in it for ages and then i cranked it (not rebuilt, was just not used for 6 months sitting around) and it wouldnt pick up pressure, so we eventually pulled one of the oil lines from the remote filter setup off and poured oil down it and it worked str8 away (must have been an air blockage in the system).
so whats the best way to get pressure the quickest, besides the method i used before as my remote filter is under the car now so its abit difficult to pull it up above the engine again.
cheers guys
Brad
I'm unsure if my builder packed the pump with vaso but I did crank it over for quite some time with spark plugs out.
As soon as I saw plenty of oil in the head (oil pressure light was still on) I dropped the plugs back in and fired it up.
The oil guage no oil pressure light went off instantly once it started.
Exciting times for you ahead. :)
I ran around like a chook with no head the minutes prior to starting her up, double and tripple checking everything...
The car was started and dumped coolant in the pit as I forgot to pinch up the inside turbo water banjo... Bugger. lol
no unfortunately i didnt pack the oil pump with vasoline, always get told these things after the build is finished haha.
so any other methods except the crank and crank and crank 10 billion times until its got pressure (with the spark plugs out obviously)?
I went through this myself a little while ago..
Heres what i ended up doing..
Back fed it through the factory oil pressure sender pickup, it'll take a while as it needs to fill the oil filter and whatever else is in there..
back cranked the motor by hand, eg the reverse direction to try and suck some oil into the pump..
jacked the back of the car up as high as it would go on the jack, and poured about 8 litres of oil into the sump..
not sure which one worked over all, as we tried a few things along the way but it picked up pressure.. we drained the excess oil from the sump, and its run fine ever since..
It was a _very_ long hour for me, so i understand what not getting pressure is like.. did you make sure the bearings copped a good dose of oil, or in my case, vasoline, whcih doesn't run off same goes for all the cam bearing etc..
pour like 12 litres of cheapass oil into her, so that the oil level is above the pump. take it all out, put good stuff in and go. it will work first time, i guarantee.
so do i crank it with 12 litres in it to start getting pressure then drain it, or drain it and then crank for pressure? :(
i been trying this arvo, poured it down the oil filter line and its got oil pumping out, though not heaps at a time, and the turbo feed is pumping oil out though not alot of pressure either, though my autometer oil pressure gauge is showing 0 still :(
will give your idea a go tommorow for sure, cheers mate for the info :(
Brad
you can do either, might as well give it a crank for a bit. can't really hurt anyway. it's mainly just to get oil in the high pressure OUT line from the pump to the high pressure bearing galleries. once it's there, and full, the pump is ready to go.
i been trying this arvo, poured it down the oil filter line and its got oil pumping out, though not heaps at a time, and the turbo feed is pumping oil out though not alot of pressure either, though my autometer oil pressure gauge is showing 0 still ;)
will give your idea a go tommorow for sure, cheers mate for the info :)
Brad
just buy a cheap ass manual oil pressure guage remove the factory oil pressure sensor hook up cheap ass oil guage in its place crank motor over (do not start)untill u get oil pressure start up car with oil guage still hooked up just monitor oil pressure guage 4 a few minutes or leave on untill warm or u feel happy switch engine off put factory oil sensor back in end of story
hope this helps u out
As cubes has done.
The ideal way would have been when the engine was out the car and on an engine stand. You tilt the engine toward the oil filter side and turn over the engine with spark plugs out until you see oil going to the head.
The next step or if the above step cannot be done, follow what Cubes has mentioned.
There is no stress on the bearings as they would have been coated with oil during the build and as there is no combustion and no plugs - no stress on parts.
i been trying this arvo, poured it down the oil filter line and its got oil pumping out, though not heaps at a time, and the turbo feed is pumping oil out though not alot of pressure either, though my autometer oil pressure gauge is showing 0 still :)
If its pumping oil out of the oil feed line it sounds like theres oil going through it, have you got the factory sender hooked up?
cheers
cheers
nah im using the autometer sender unit, which worked fine about 6 months ago when i last tried it, so im just thinking it aint cranking fast enough to produce full pressure. the gauge goes to 0 when i connect it up so i'd assume the gauge is working fine.
its got the jun oil pump which flows alot more, but would take more volume to get it full and flowing properly i'd imagine.
so yer oil is coming out of the turbo feed slowly, not a full tube of pressure though, but thats cause its only cranking maybe?
oil filter is pumping oil through too, i just dont really wanna start it at all till its got full pressure, as if i start it and it doesnt create full pressure it can cause alot of damage running without any oil whatsoever (except the oil from rebuilding and assembly, which wont last 5 min at 1000rpm per minute.
do u guys know if i need more revs to get the JUN pump flowing?
thanks for all the info/ideas people, much appreciated
Brad
i have an old BBQ bottle that i have welded a filler and a thread for a gauge into.....then what i do is fillit up with oil,pump it up with air and screw it into the sender hole......open tap and it floods all the gallerys with oil....same as if the engine was running
  • 4 weeks later...
"I ran around like a chook with no head the minutes prior to starting her up, double and tripple checking everything...
The car was started and dumped coolant in the pit as I forgot to pinch up the inside turbo water banjo... Bugger. lol"
done the same thing :mad:
Every engine i build i turn upside down on the engine stand before the sump goes on and put a funnel in the oil pickup hole ,fill with oil and turn the engine over with a big bar onthe balancer bolt until oil comes out the cams etc then sump on ,cam covers on and in the car start it up.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
