im really interested to see if anyone is running a gt30 500hp turbo on their rb25 on these forums with an a/r.82 exhaust housing and if so what power are they getting in rwkws and at what boost pressure and rpm does it reach full boost by with what supporting mods??? cheers carl.
in the 500hp the .63 really doesnt choke it, its when you get the slighty bigger comp wheel for the 550hp that the .63 would hold back.
i reckon the 550hp would come a damn sight close (if not make) 300rwkw on 20/22psi if in a .82 rear.
I went 270rwkw with 600hp on 17psi.
But then, when your talking 10/15kw thats a simple matter of dyno calibration really, your 280 could be 265 on the dyno i was on, or vice versa... if you see where im going with this :unsure:
Its hard to compare 10/15/20kw differences IMO.
yeah the .63 would probably be the better choice, gives better low end grunt. all the .82 would do is lag your combo out, unless you also go the bigger comp wheel as was stated earlier by R31Nismoid. all you really need to get more potential from your turbo is cam work, forget about a larger A/R turbine.
bugger all if you ask me, maybe 20rwkw which you wont really feel.
i doubt id feel 280 going to 300, maybe @ 150rwkw going to 175 or something you would :)
i went 270 to 330, that i noticed :(
wow , a few different answers there. does anyone know what the difference would be in rpm, what 300rpm , 500rpm? to spool up to full boost? i thought that posting here i might get some intelligent answers?? instead i get," i can get you a dyno print out for 300rwkws if you like". if i was just after outright power i wouldnt be playing around with such a small turbo would i? all im trying to do is discuss my options before going ahead or research before going ahead, i appreciate your help so far guys but weve come along way say since the sub zero workshop pulled 10.9 in a skyline over 5 years ago. they were using two of my turbos to pull 330rwkws . this was and is still impressive but now lots of peoples skylines are doing it and probably with less lag than is associated with two big twins. im just trying to see before i try to extract a little more. im a very happy with the way it drives at the moment and yes power does come hard at 3500/3800rpm. with boost starting at just over 2000rpm. has anybody actually driven or owned a skyline with a gt30 500hp rated turbo with a a/r.82 exhaust housing? because if it takes another 500rpm to spool the thing then know i probably would not bother but if its less than i would probably consider it.
Edited by bigcarl
ive already got 281rwkws with a/r.63 exhaust housing, thanks for reply anyway.
I've got the same setup making 225rwkw... can you tell me your other mods?
(I'm running standard internals and 16psi boost)
low mount stainless manifold, ces split 3 inch dump pipe into a 4 inch magic cat, then 3 inch continueing to barrell style muffler with 4.5inch tip. 600x300x80mm front mount intercooler with stock plenum and pipeing. link ecu running 550cc injectors. splitfire coils. motor has been fully rebuilt with wiseco forged pistons on prepped gtr rods. running 8.5 to 1 comp. head mild port, running tomei poncams step ones 256inlet and exhaust, no adjustable cam gears. 600hp bosche fuel pump. i hope i havent left anything out.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
