Hi i recently got my Ps and started driving my 92 R32 GTS25 by myself and i have filled up twice now and i think im getting really bad fuel economy. Im a pertty big noob when it comes to cars so i couldnt really tell u wat mods i got. Both times i did around 320 km per full 60L tank and i asked a few ppl and their gtrs do better then that so im just wondering if there is anything wrong and if your guys got any suggestions thx
https://www.sau.com.au/forums/topic/106384-r32-fuel-economy/
Such a large factor with fuel ecconomy is dependant on how the individual drives the vehicle...
e.g. Car: R32 GTS-t
Mods: Lots...
Good week at work, 400kms easily...
Sh*t week at work - girlfriend - momentary fits of rage, 253kms (and own PB)
It really does depend mate... also, mods? Any? It's an RB25, and you might have your lead shoes on...
But around the 330 - 400 mark I think you'll find is pretty stock standard.
Cheers. :unsure:
Do a major service on your car, something sounds wrong on yoursl ...my r32 na does way better than that on a full tank like 400-500+kms., with the occasional flooring it lol.....
some advise, watch your fuel guage when driving normaly, then watch it when you floor it a few times the fuel guage shows how much you really use when doing that.
Edited by NeesaanGTS
auto rb25t with 190rwkws and i get 370 to 450 from 60l champ
thats 15L/100km ! thats hardly good either..
acidkid: if yours is auto that could explain a lot.. seems like economy on the autos is quite a bit worse than the manual.
I get something like 130 - 140 klms per 15 litres for my manual r33 - Though just today i got 120 in about 20 ltrs ( but thats cos I had a full tank, and i was demonstrating the turbo for a couple of my friends).
who cares about fuel economy, you drive a skyline not a toyota echo,
if i want fuel economy i wouldnt be driving a skyline,
enjoy it while petrol is still affordable, theres less and less oil in the world, in 10 years time we'll prob be paying $2- $3 a litre
yeah. at the start of each tank i've been known to say many a time "okay, no hooning it for the whole tank to see how many Ks you can get" ... well, that plan always goes out the window.
i get a bit over 300km to the tank most of the time. i should change these o2 sensors like everyone says! i have trained myself to always just put it in neutral down hills and rolling toward the lights though.
my car is r34 gt4
i got 21 litre per 100 km
i think it's very bad
i already check once by maintenance man. they check exhaust emission. and said no any problem...
i want to know: how to check o2 sensor? and can inject oil to tank fix problem?
i bought this car form japan, nobody driver it in nearly half year, is this reason for fuel problem?
if your car was turbo i would say that u should be able to get more but NA you should definately be getting more, probably should be closer to 450. Definately get it checked out by an EFI diagnostic center.
Edited by RRR32_GoDzIlLa
If you put it in neutral that would use more fuel according to my understanding.
When you put it in neutral the motor has to dump fuel in to stop the car from stalling. If you are rolling down a hill or rolling towards the lights in gear you are using less fuel because your motor is turning itself from the momentum of your wheels. I think most ECUs cut fuel on deacceleration.
Someone correct me if I'm wrong.
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
