Hey everyone.
Im currently in the middle of modifying my R33 GTST
Top mount manifold
TO4e Turbo
40mm external wastegate
Apexi Power FC with HC
Front mount (600x300x76)
K&N 3" Pod
Bosch 040
Apexi AVCR
Sard Fuel Pressure Reg
Hi Flowed injectors
Upgraded spark plugs
Front facing Plenum
XF Throttle Body
Mandrell Bent 3" Custom cooler piping
Z32 AFM
Oil catch can
HKS SSQV Bov
I'll be on a full licence when its back on the road
How f@#ked over will i be if a cop pulls me over or if i get sent to epa
wat will happen
Is there anything i can do to legalise it
Engineers certificate???
Need Advice fast lol
Thanks for any help u can give.
Cheers
Guesty
https://www.sau.com.au/forums/topic/106481-wat-2-do/
Dont bother with an engineers certificate as it says on the bottom in huge writing "Valid For Only 30 Days After Inspection Date"
Dont think you can legalize it due to the fact that the turbo and everything else helps to increase your emisions.
The engineers certificate is good for proving structural changes in your car are safe and legal.
https://www.sau.com.au/forums/topic/106481-wat-2-do/#findComment-1963645
nothing you can do
with a highmount (and a crappy one at that ;)) your 100% f*cked
External Gate - 100% farked
modded plenum/Throttle Body - 100% farked
If i were you, i'd be very careful when/where/how you drive it
If they catch you.
You have to return it to 100% stock.
STOCK everything right down to the injectors and fuel reg :(
Pray to the gods is all you can do on that one
Engineers does not cover EPA in any form.
https://www.sau.com.au/forums/topic/106481-wat-2-do/#findComment-1963690
If they catch you.
STOCK everything right down to the injectors and fuel reg :)
Hey Ash
Is putting in bigger injectors, and an aftermarket fuel reg defectable?
https://www.sau.com.au/forums/topic/106481-wat-2-do/#findComment-1963743
I know someone with a very similiar setup who was once pulled over by a cop and asked to pop the bonnet and the cops didnt say anything as they looked very confused at what they were looking at in there. :(
Guesty if your gonna do this setup then I would get another car an a daily driver coz u r sure to get done if driven around everyday.
Dark most cops aint gonna pick aftermarket injectors or fuel pres regs easily.
https://www.sau.com.au/forums/topic/106481-wat-2-do/#findComment-1964863
  • 3 weeks later...
