anything recommended, want my car to sound nice. does a full exhaust system include the extractors?
You mean the manifold?
That will cost a fair bit I think and most people get stainless custom welded ones if replacing usually.
Just look at getting from the dump pipe back (maybe a hi flow CAT as well) which will cost around $1000-$1200 for a decent one.
https://www.sau.com.au/forums/topic/106499-turbo/page/2/#findComment-2214519
  • Replies 71
Posted Images
But it is a fact. Garrette oems for hks. That came from someone who worked for hks, so i beleive it's pretty reliable. They might be of different specifications but almost similar, and the other big difference is hks makes them as bolt on kits and garrette u have to custom most stuff stuff.
Yes, they OEM for them. But to HKS specs.
So they are never the same turbo.
https://www.sau.com.au/forums/topic/106499-turbo/page/2/#findComment-2216307
being that your car is turbo you wont have to buy extractors as they dont have the same manifold setup as a non turbo car.
You could buy an aftermarket low mount stainless maniofold if you wish, however its not really needed.
Just purchase a full 3 inch system from turbo back with a high flow cat and a single muffler on the rear.. That should give the note your looking for.
https://www.sau.com.au/forums/topic/106499-turbo/page/2/#findComment-2216602
yeah they do, i think they thought for them to supply them for me. anyways. what do yous think of a full 3inch turbo back exhaust with a hi flow cat back (if that sounds right). please give me some places to go to.
https://www.sau.com.au/forums/topic/106499-turbo/page/2/#findComment-2221364
you can save yourself a bit of money buy buying the parts from online shops and getting it delievered then installing yourself
it is not a very hard job to do the turbo back exhaust you just need to be keen with the right tools and a days time should be good to go
i got 3" dump and front, then HKS muffler and my rb20 has a nice note the one you are looking for...
https://www.sau.com.au/forums/topic/106499-turbo/page/2/#findComment-2227734
exhaust for me:
cannon N1 style muffler: 100
custom 3 inch cat-back mild steel straight thru piping (only two bendsin whole system!) - 150
cat: was already three inch- FREE
Front pipe dump/pipe: 200 (Jshop) havent got this part for myself yet, just stating price
total cost: 450
hearing it pop and fart everyday: priceless
*miss my cannon system :D*
Edited by J_R32
https://www.sau.com.au/forums/topic/106499-turbo/page/2/#findComment-2228725
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
