My current mod is 3" HKS exhaust, Blitz downpipe, Trust oil cooler, std intercooler, std ECU. Intend to upgrade to HKS Type S intercooler + Boost Controller soon.
What would you think is next best upgrade, ECU or Turbo first? I am not looking for high HP but more streetable power when the need arises. From what i know is the std ECU won't boost more that 0.8bar.
If it was ECU, should i go for F-Con Vpro or Power FC? Pls factor in cost also.
If turbo, should it be HKS GT-RS or HKS 2835? What are the characteristic for both turbo compared? intend to boost 1.0bar for daily driving. Need advice...thx in advance :)
What you guys think of the FCon V Pro? I know some prople who can bring the Japs and tune but quite costly. But it has one function that once the A/F is fixed to a certain amount, whatever boost you run the fuel will be optimized for it.
I like Power FC but is it easy to learn to tune by myself on the road or dyno? :)
1. What you guys think of the FCon V Pro? I know some prople who can bring the Japs and tune but quite costly. But it has one function that once the A/F is fixed to a certain amount, whatever boost you run the fuel will be optimized for it.
2.I like Power FC but is it easy to learn to tune by myself on the road or dyno? :)
1. In order for the FCon V Pro to "self tune" it would need a wide and fast lambda sensor and extensive interpretation hardware and software. I have not seen any evidence of that.
2. If you have a stand alone A/F metre there is no reason why you couldn't tune any (tunable) ECU on the road
:) cheers :D
IMO, and sure this will be flamed by many other forum members, I just don't agree with buyign a powerfc, paying 500 for a tune, and then having to tune it again after you get your turbo.
I am still saving at the moment to collect all the parts I need and then i'm going to do them all in one hit.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
