How about a graduated two colour effect with a graphic design. You could respray the top of the car something complimentary to the silver, say a deep purple, with a nice graphic along the side to form the seperation. You can respray the bonnet to match, which would give you a classy new look, without the pain of engine bay, inside of doors etc. You could cover the whole lot in clear. Some very trick custom cars have this look. B)
I was fooling around with this a while back so thought I would stir the pot with a few pics! Not fantastic but you get some idea...
Green:
Bronze:
Midnight:
Blue/Green Pearl:
Candy:
Apologies to the actual owner of this Stagea, not sure where the image came from now...
Cheers
Luke
Yep, that purple one does it for me. Mind you, they all look good. Shows what a nice beast the Stag is to work with.
If you are going to be using it as a daily driver, something like that would be good. A full custom Kandy Pearl coated number would be a mite tempting for a bogan to scratch.... ;)
that green on munchdesign's post looks hot on a stagea.
it looks like hot house green, which i was leaning towards doing.
but after seeing that picture i definately think thats the colour.
looks sweet..
Dont forget the red pinstripe either (complemantry colours), and smoked rims. Would look real nice. :P
But that blue/green pearl looks HORN! :lol:
  • 4 weeks later...
i think the red from the ba XR range is great. real bold red. and a white starsky and hutch stripe going over the plastic bit between the rear windows. it'd suit the lines perfectly.
i'm not ready for racing stipes yet though hah!
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
