  • Replies 52
yeah the back compartment is kinder cool...i like the fact that i lifted up where the spare is to find the nav system and that funky lucky horseshoe mat protector...that took me by surprise....
went for a drive in it a short time ago..hehehehe have to laugh the surprise look on the faces of ppl wonder what the hell it is....made my day :rofl:
hey wildcat congratulations on the new arrival, and mr gts-t as well :P
mines running sweet at the moment so im up for a cruise when ya all want to. i took it on a toyota cruise and got a few looks when they heard it rumbling in and the twin plate clutch rattle, they new it wasnt a stocky :P
hoping for the power tune in the next week or two depending on how busy the tuner is when i ring them early this week.
do u and brett want to meet up one arvo after work or soemthing for abit of a looksy at each others cars and abit of a chat sometime?
lee (Stage-A) only lives in brighton too so im sure he would be keen to come have a look as well down at a local carpark or something for a while.
cheers
Brad
Edited by CruiseLiner
thanks Brad...very excited its a bit surreal at the moment cant believe it is actually sitting in my garage :glare:
so you finally fixed at the problems you had with yours then???
would absolutely be up for catch up and looksy esp now yours is on the road...gives us all a chance to show what we got :laugh:
thanks Brad...very excited its a bit surreal at the moment cant believe it is actually sitting in my garage :wub:
would absolutely be up for catch up and looksy esp now yours is on the road...gives us all a chance to show what we got :P
yes ive fixed all the problems, haha, except a minor cam seal oil leak which im fixing today hopefully if nissan have the parts in stock, im going up now to see :)
then its all go and hopefully no more dramas :P
the 4000rpm rev limit makes it not soo fast but it still sounds like a beast :D
hey brett my mate spotted a black stagea at currambine shops the other day (not sure which day exactly) and he said it looked mad as in black :P
im bettin it was you? my house is literally 20 secs from currambine shops too :D
damn i missed it, and damn i want a black one :D
^^^ you can come along as long as you behave yourself with that lead foot of yours :D
I only put my foot down that time cause I wanted to make sure the gauge measureing the front torque was wroking..... :D
hey brett my mate spotted a black stagea at currambine shops the other day (not sure which day exactly) and he said it looked mad as in black :D
damn i missed it, and damn i want a black one :(
Could of possibly been me.... I have been up to Supa Cheap a few times buying bits and pieces, so have been around joondalup drive a fair bit.....
Either that or there is another black stagea doing the rounds in our area.... :ermm:
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
