Hey guys,
Just wondering are there anyways of checking a 2nd hand rb26 (which is out of the car) to see if its healthy or not? What do you need to look out for? :) Any tips will be appreciated as I am considering purchasing one.
Thanks
Phil
https://www.sau.com.au/forums/topic/106580-rb26-which-is-no-in-the-car/
If you can't open up the engine (remove head and sump) then you could do the following.
Compression and leak down test, most auto workshops can do it. This test will give you an indication of the health of the rings / bore and valves.
Start it if you can.
Pressure test the cooling system.
General look of the engine, is it clean or is there oil and/or coolant stains.
Do the turbo shafts have any play.
Does it show any signs of serious heat stress - burnt paint or melted electrical connections.
Is there a hole in the block with a conrod hanging out of it :)
May not tell you much, but you could check the condition of the oil (if it as the same oil it was last running with)
If you can pull it apart:
Remove the cam covers and check condition of everything in there - cams, lifters, valve stems, etc
Remove head - check condition of bore and pistons
Remove sump and check big end conditions - bearings, crank etc.
Other than that - take it to someone who knows what they are doing.
well u cant really do coolant presure check with it out of the car. compression test is a must!. look of the engine. remove the oil cap and not any gunk around the lip and any white coolant around the cap.. white noramally means coolant leak(blown head gasket).. check seals. u got engine out cheack rear main. turn the crank over a few times.. if the engine is really bad it might make a noise. inspect belts. check tappet cover gasket. check sump seal. check if the nissan stickers on the exhast cam have been ripped.atleast take a plug out inspect tip. look down the plug hole inspect carbon build up.
get a warranty on it.
what is the purpsose of the engine? gonna drop it in a gtst? a silvia..? ;) hope it helps.
Thanks for the help guys.
No warranty as this is a private sales. Well i am either gonna go down the road of rebuilding mine, or getting a 2nd hand motor for my r32 gtr. cheaper to buy a 2nd hand motor, but im worried i will buy one that will only last me a few 1000k's. More expensive to rebuild but at least I will know its going to be reliable.
the guy selling the engine is pretty close to me and I think its bet I take it down to a workshop for the pros to check it for me.
Hes actually selling the motor here. maybe u guys have seen the thread. This is the picture he sent me. what do ya think?post-23859-1140430907.jpg
Edited by PhilGTR
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
