The other day I mounted a bosch 044 intank in my r33. At first I left the one way valve thingie on, finished the install and the car didnt start. So I pulled the pump out again and removed the valve as I had been told by another r33 owner he did it the same way with no problems.
Well the car ran perfectly for about 5 mins then it stalled. And now it wont run any longer then 10 seconds.
It sounds like the car is running out of fuel but it isnt. I took the hose of at the fuel filter to check it wasnt a clogged filter or something but there seems to be a nice flow happening.
Any thoughts?
Any one else think its not pump related?
Thanks
David
https://www.sau.com.au/forums/topic/106601-need-help-with-044-install/
YEP, you need to bypass the fuel pump controler. (drivers side on the parcel shelf)
basicly run a seperate earth to the pump directly, also run a power wire directly to the pump.)
the relay is on the side of the boot fuse box.
if you can, remove the fuel damper of the fuel line in the tank (the metal thing inbetween the pump and the sender)if it has it....
its purpose is to "dampen" the fuel lines, to stop the hammering noises you get through the lines from the injectors pulsing,
this device can cause the pump(bosch roller cell) to cavitate when the fuel is hot.
the 1 way valve should be removed off the pump to
(unless you use banjo fittings on the pump with a cap bolt on the pump ie:blocks of the thread on the pump fitting with the banjo fitted..)
Ok thanks for the help. I already earthed the ground of the pump. what should i do with the earth lead that goes back to the power fc? Ground it or leave it bouncing up and down with the road??
R31Nismoid ive read that diy aswell as many others and no ones had this problem.
Thanks again ;):D:D
edit. I also drilled straight through the one way valve so I can get a hose to fit on it :D
Edited by 33SOM
I just hooked up a 40 amp relay directly to the pump. It sounds healthier now but the car still wont start.
I also took TO4GTRs advice and bypassed the fuel damper thingie and still no go.
Anyone got anymore ideas?
Im about to throw the standard pump back in to make sure it is the pumps fault the car wont start...
  • 1 year later...
  • 7 months later...
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
