Ok i have spent about 3 hours searching through the forum but can't find what i am looking for..
Could you guys recommend me a good clutch..i had my eyes on an exedy heavy duty but was told by a machanic that they don't last long about 12 months max. he recommended extreme but they are like $300 extra..
What i want is a clutch that last me the longest because it is a bit of a pain replacing them all the time..
what you guys think is a good clutch that last but not to difficult to drive?
thanks in advance..
ps. i got a GTST -II and in melbourne..
https://www.sau.com.au/forums/topic/106603-what-clutch-do-you-guys-recommend/
If you read what he was saying, you'd see he didn't want to spend $300 more on the xtreme.. so of course he would want a jim berry ;)
Well unfortunately if you're on a budget, your options are a little more limited.
There is an Xtreme full face organic for around $350.. which would do probably do the trick. Best to speak to Xtreme Sales, to ask what you might need and they will put you in touch with a local distributor who can give you a price :D
Thanks guys..
i knew about the Jim Berry but he's in qld.. and i m in vic..
i rather pay abit extra for something that last longer..and still drivable in city traffic.
i am willing to pay up to $1000 (fitted) for the thing .. any particular model you can recommend?
Thanks guys..
We do have couriers and AusPost these days :D Seriously, that's how I got my clutch to Jim. Was about $30 through Express Post.
If you're willing to pay up to $1000, I would get the Jim Berry "Stage One". Its about $700, and fitting will probably be another $300.
God damn. Exedy cheaper than exedy? That's news to me. For $1000 you can have an xtreme clutch. They're like $400!!
I have a 9puk cerametalic whatever with 860kg pressure plate. Pulling 200rwkw, goes fine, would buy one again.
thanks in advance..
This is only my opinion on how to choose a clutch but I think it works really well. Once you've figured out what you want / need in a clutch, then pay a "decent" amount of money and get a "decent" clutch that meets your needs ( even if that means not getting those 24" chrome wheels for another 2 months :O ). If you buy the CORRECT clutch, you will enjoy driving your car more, the clutch will last longer causing less headaches in the long run and you won't risk causing damage to your car ( killing the pedal box welds, master cylinder or slave cylinder or killing the gearbox itself ).
Honestly answer questions like..........
- What power do I want it to handle ?
- Where do I do most of my driving ? ( Cruising, Commuting, Drag Racing etc. )
- What is my driving style ? ( Smooth, Agressive, Both etc. )
- What kind of pedal feel do I want ? ( Heavy Button Style, Progressive/Stockish, Progressive/Heavy etc. )
- What CAN I honestly afford ? ( 24" rims scenario )
Once you know what you need, find out what's available that meets your needs ( heaps of guys on here can recommend something that fits your needs once you are specific about what you want ) and then buy it. Do this instead of saying "I've got $500 to spend on a clutch. What's the best I can get ?" and you'll be a lot happier in the long run.
:end rant: :(
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
    • *waits* for chop idle videos and TT kit hanging off the motor. I like these sounds now, my inner bogan is growing.
    • Want to buy a good running Rb20det in Sydney preferably complete or long block
