It will be near impossible to remove it completely. I rented a place before with a really stuffed up driveway. Everytime I drove up the driveway, my inside wheel would spin. After about 8 months, there was a pretty thick tyre track on the ground.
We tried petrol, kero, turps, everything. We tried scrubbing it with the chemicals mentioned above. We tried applying the above chemicals, then lighting them on fire. We tried using a gas cylinder as a flamer to try and burn it off.
While all these made it better, it was still quick noticeable.
Just paint over it and be done with it.
yeah ive had the same problem at a place i rented ages ago. i found using a wire brush and a heap of washing powder (nappy san or similar). Have ya tried a pressue washer/gurney, or HCL over the marks, if that doesnt work then ur probally screwed. ;)
god. i read you post and i PMSL ;)
anyhoo citroclean is agressive as. it removes polish off the floor so it should make a dent in it at least. try a few application of it to remove it. ie put it on and attack with a stiff brush, wait a little then put more on and attack it again.
anyone tried CLR?
if all else fails buy some grey paint lol
Your local auto parts supplier should have a range of concrete cleaning products.
I used one a while ago, very caustic stuff, did a good job of removing oil stains, but I don't know how it would go with rubber. (I guess essentially they're the same compound?)
Hose the area, dump the powder on, scrub it, let it sit a bit, then hose it off.
But if you're going to use anything like that, suit up well.. it burned little pitted holes into my leather work boots.
Theoretically yeah, they're both hydrocarbons. Which means they should both react (to a certain extent) to other hydrocarbons, especially volatile liquid ones (kerosene or petroleum solvents).
I still pity the fool that shits in his own backyard.
God invented rental properties so that people could shit in their own backyard, then move along to the next place when the shit can is full :D
Be mindful with whatever you're using that it's possible that anything that would dissolve the rubber by making it softer is likely to sink into the concrete (especially if it's really porous).
Obviously if whatever you're using eats all of it away that's fine, but sometimes chemicals tend to do a half assed job.
alternatively... soak your tyres in diesel, then proceed to drive up and down the driveway evenly.
then give the landlord a bill for treating the driveway with waterproofing silicone.
i used to work at Golden Circle, and they got this stuff that'll burn the skin clean off your hands...
wen u squeeze the peel of an orange u get this acidic juice... they process the stuff into wat Golden Circle call "citrus oil"
if you can find that, u got no worries
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
    • Barrels don't need to be shiny clean. But they are certainly nicer when they are not polluted with years of brake dust, and worse the rotting corpses of the last 17 balance weight sticky pads scattered all around.
    • Yeah, type a special character like ^ or | to initiate the equivalent of the "at"ing for thread links. Although, it might not get any easier to manage. Imagine 30 or 40 threads that kinda match what you want, and the one you want is lost after a long list of useless ones. The magic keyword version I proposed would be a manual effort to set up each case. More of a directed effort from the greybeards to facilitate exposure of useful content. I'm not against the auto complete stuff being considered - maybe por que no los dos? (And where I said "triggered automatically" in my OP, I meant "triggered accidentally". Of course I want it to be automatic!!)
    • Ah yes, fair enough! I was purely thinking about cleaning the spokes and front of the wheel with the mitt. For the barrel the rag on a stick makes more sense. I've tried cleaning the barrels on mine and gave up in frustration. Between brakes being in the way or spokes being in the way and limited space to constantly move the car front and back it was just too annoying. The barrel being as shiny as the rest of the wheel sounds amazing though. At this point I'm not even sure if they have the same surface finish on mine. But I feel inspired now to find out.
