Roy I did see mention of an early stripper verson that was supposed to be ~ 1170Kg I'd imagine with no pwr steer or A/C and armstrong window winders . The std 60mm piston cast steel calipers are quite heavy so the change to R32/Z32 alloy four pots would be equal or less . As you would know the more performance minded R32/33/34 rotors are bloody heavy because of their size and thickness . If you did the front brake conversion properly ie disks bolt to back of hubs not over studs you could probably have a 1200Kg car in road trim . If the sound deadening was flicked and a lightweight seat fitted is better again , and an R32 GTR radiator (honestly about a third of the weight of R30 dinosaur) and it goes on . SK once spoke of aluminium flywheels and his RB31DET - works well and saves weight . FJ20ET's have a pretty large (for 2L 4 pot) 240mm flywheel so a bit to lose . The "right" wheels such as Rays (Volks) have the right offset and are very light for their size (16x7 , 16x8) , have to assume they have forged centres and rolled rim sections .
The R200 and thicker half shafts put a bit of weight under the bum but its needed to be reliable . With a bit of stuffing around you can get an R32 GTST box in (change bell and bore lower bearing hole) , same length same yoke .
Cheers A .
According to the Nissan Skyline brochure I have the following TARE weights apply.
2000RS-X sedan 1105kg, and coupe 1115kg both fitted with FJ20 engines & manual transmission. add 10kg for auto
I would assume the coupe would be a little heavier because of the extra glass in the coupe. Glass is heeps heavier than metal.
The respective same in GT-ES L20ET engines is 1150 & 1160kg
And an RB 20DET is about 15kg lighter than an L20ET
The front to rear difference is about 1/3rd
Remember these are factory bone dry tare weights and probably have no resemblance to reality, when considering the scale weight of the Powerplay Imports DR30
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
