Hi guys, I'm from Malaysia and in our forum, we have a hot topic about this...anyone of you guys tried it before?
The question arises when an A31 was smoked by an M3 on a Malaysian highway on top speed, and because of the car age, the chasis is a big issue whether or not it will support up to 300kmph of G-force, even if the car has a full anti-rollcage and strenghtening bars in it....
currently the vote is 90% of the Ceffy owners saying it was impossible to chase down an M3, M5 is of course out of the question...
I'm with the remaining 10%, 'cause I've tried it before...what do you guys think, pls share your ideas, comments and experiences here, thanks in advance!!!
I don't think 1JZ conversions are that common in Malaysia. Last time I was there most of the guys were running RB25DET's and RB20DET's. Thailand is the capital of 1JZ conversions.
5000rpm in 5th (s13 engine and gbox) with my car has been done. I'm not sure how fast that is but at that speed with foot fully off the accel it took 7 seconds or so for the speedo to get back to 180. Done without a wing.
So with a huge wing, some racing decals and better tyres I don't see why a cef can't do 300kmh.
I'd prefer to be in the BMW though.. Just something inherently safer about a german made car designed from the factory to test the limits of human terminal speed courage/stupidity :D
Gearbox and diff would be required. To lengthen range.
I have 'seen' 6700 in 5th and it was off the speedo for about 30secs to a min to get to that. Est speed around 220. So with a little more it could make it.
Goes from 120 > 180 very quickly once the turbo comes on and engine is revving. Probably 5-10 sec acceleration time.
Would be a monster if it wasnt revving so hard. This was with standard everything. Never been in an M3 / 5 so not sure how fast they are. :P
I'd be quite happy to drive a Ceffy at 250+ with standard chassis.. As long as it had some forgiving coilover settings with strut braces.
Anywhere over the 300rwhp mark should give the M5 a decent go?
I spose there's always option of a 100 wet shot nos setup :(
I think you should provide a link to your forum so I can check out some 1jz conversions :lol:
Thank you.
here's the link...http://www.zerotohundred.com/newforums/showthread.php?t=2547
and just to inform you, because of government regulations, doing a transplant of engine of different car brand (like toyota engine into Ceffy) is not permitted in Malaysia.
Is the limiter of BMW cars really set to 250kmph? no wonder when I was chasing that M5, it only tops 250kmph, won't go faster anymore....and just to let u guys know, the road condition is not that good here, even on a highway, doing 300kmph would be suicide...even with a full anti-roll cage, best suspensions and great tires.
in the same car I hit 5800 rpm in top and there was still more
yes definatly doable even if a bit hairy especially on bumpy roads 7500 in the same car would be 300 kph from memory. the killer in that car is the 100-to 200 kph time 5 or 7 seconds ( never timed it as your too busy concentrating. 270-280 is definatly achiveable approx 7000 pm.
the cefiro is pretty areodynamic for its age 400 hp + @ the engine would be needed
meggala
5000rpm in 5th gear (in my car) has me sitting at about 240kmph - 250kmph
but I have had a chance to wind it right out to see what it would get to.
But bearing in mind guys the that going from 290kmph to 300kmph the wind pressure on the front of your car almost doubles.
The Cefi's rock... but I think the M5 produces like 450bhp?? That's a sh*tload of power for a stocker... but as someone has duely pointed out.. most BMW "performance cars" are speed limited... that removed, and they can let their full "autobahn" potential be realised.. in short.... cefi would probably get drilled.... Unless modified to a similar spec.
Edited by QUIKBLADE
Tad over 500hp if you use the right settings. Too many buttons to push, by the time they actually have their car set for 500hp, the cef would have lapped it twice :D
The fastest I have been in My C33 Laurel is 255kmph. This is with 8 Point Cage, Swaybars, Strut Braces, Coilovers, 300hp RB25det etc.
So yes I would say definately achievable, jsut with the right Modifications.
You must respect the M5 though. It standard could beat alot of modified C33's/A31's. I have never raced one but I think once I got past the Lag factor It would be on like Donkey Kong.
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
