1989 Nissan Skyline 4 door R32 gts-4 - Grey - M-Spec
Selling due to lack of funding for an operation.
Has around 90,000km's on the odometer with Rego til November
RB20det (turbo) 5 speed manual
Same driveline as a GT-R
Has the same brakes as a GT-R
Vacuum hoses in the engine bay have been replaced with Blue silicone ones and yellow zippy ties.
Stainless Steel piping to and from the side mount intercooler.
Car comes with FMIC piping but no front mount.
GT-R fuel pump
Clutch has recently been replaced.
Exedy Heavy duty Clutch
GT-R mags 16"x8"
fronts: 225/50/16
rears: 225/50/16
Full coil-over suspension TANABE
Bodykit consists of front bar, side skirts and skirts behind rear wheels.
Skirts for behind the rear wheels have not been fitted.
Extremely dark tinting on rear doors and rear window
Turbo back 3" exhaugst with a rather large genuine Apexi muffler
Boost Gauge
GFB Bleed Valve
JVC KD-LHX505 Touch screen headunit
Front speakers: Infinity 4x6's
Rear speakers: Pioneer 6" 2-ways
Asking $14,000 ono
Phone 0402 366 481 if you are interested
phone between 3pm and 8pm during the week or
phone anytime on the weekend
pictures are available on request
  • 3 weeks later...
  • 1 month later...
  • 6 months later...
  • 3 years later...
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
    • Glad it eventually came out Duncan!   I believe that might be 040. 044 is the inline pump, so has screw fittings in and out. 040 is more just drop it in fuel and the bottom is "open" (mesh) from my memory
