im in the middle of purchasing some coil overs for my HCR32, but i dont know what spring rate i should get... the car is used for drifting purpose's. could someone kindly help me out :D
ive been told that a 6kg front and a 8kg rear set up would be awesome for drifting...
Brandon
https://www.sau.com.au/forums/topic/106691-hcr32-suspension/
no i havent parts for the skyline are pretty hard to come buy here in BC canada what company makes stabilizer bars...
even with out them what would be good?
Brandon
OK, so you are going to use the springs to do their own job, plus the job of upgraded stabiliser bars. Are you going to drive it on the road or only drift with it?
:P cheers :D
PS; I can send Whiteline adjustable stabiliser bars to Canada, I have done it before. There is a Whiteline agent in the US, but he mostly carries WRX stuff, I don't think he has any Skyline parts.
im in the middle of purchasing some coil overs for my HCR32, but i dont know what spring rate i should get... the car is used for drifting purpose's. could someone kindly help me out  :(
Brandon
the trend with drift spring rates, seems to be to have higher rates on front and softer on rear.
a common combination is 8kg front / 6kg rear
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
