Recently had a short circuit (sub box connections loosened>touched>blew a head unit connections making it go pop badly on powerup).
:) Anyway, that's fixed, but the auto-elec said my battery might be gone cos while working on it with the key in the accessory postion and engine off, it died after about 10-15 minutes. They said it should last a coupla hours at least if the stereo isn't on. Annoyingly, they didn't say "you need a new battery" or "we should check the rest of the system for grounding" etc... u know what I mean? Couldn't give me a straight answer ;)
So now I'm worried cos I'm about to get my stereo upgraded and if the car's struggling to hold charge 10 minutes then I want to fix that first. I already jump out of the car and lock it real quick out of paranoia :D
So I'm gonna check the battery manufacture date. How can I tell how long it is into it's life? I read some batteries last 2 years, some 4.
If the battery isn't long in the tooth, I'm gonna check what the nominal amp being drawn from the battery is while I'm parked. I read it's supposed 50mA (plus whatever the boot light draws if on). Is that correct? Roughly same for all cars? Mine's a '96 R33 GTST.
Also, the auto-elec said I need a "sealed" battery. That's what's in there at the moment. Somewhere else said that's a load of hooey. What does everyone else have? The battery in there at the moment looks a lot smaller than the seat/frame it's sitting in. I think there's meant to be a larger battery there... After checking there's no crazy draw on the system while off (and fixing that if there is), if I need a new battery, what's the biggest/longest lasting one that will fit in an R33 2 dour?
BTW, the audio system isn't anything crazy, so don't think I need a second battery etc. It's a 700W rms 4 channel amp, off a JVC head unit with focal splits and a 10" sub.
you answered most of all your own questions there buddy . the autoelec should of told you so you stop guessing your self . if its been in front of an AE then he could tell in 1 second if the battery or Alternator is fragged .... it is!!!, i can tell by what your saying ... replace it and forget about it hassling you ......i went the biggest fatest exide that would fit and repaced terminals with contact luggs ... not a hicup now !!!
mine was the same, came with jap battery .... there ok until you slowly drain the old one of power somehow (bootlight stereo etc) and they seem to cross a cell making it a 12 volt battery still but no staying power .....
lol jap batteries are crap thats all there is to it. if you wanna run subs n all that shit off your car with a jap battery and dont expect it to go flat after having it on accessorices for extended periods of time.... your dreamin
ishh: The auto electrician I dealt with when picking up the car was some mongrel obviously in a big rush (for *#& knows what reason, it wasn't lunch or the end of the day), and he barely spoke a word of english, hence me walking away without a clear answer simply cos I couldn't understand him and noone else was around.
JaR: Who said anything about a jap battery? From memory I don't think it is jap. And I said I jump out of the car real quick... obviously I'm NOT sitting in the car park with the shit running and the engine off.
Thanks so much for the genuine non-sarcastic help...
1. most cars have batteries that are really old. Why not replace it if it's 5 years old?
2. batteries are cheap. head to our group buy section and pay 140 for the sealed battery from wrxhoon and be done with it. You won't have to worry about battery again.
3. stop stressing, it's only a battery. it's only 140.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
    • @Kinkstaah I've got my list.. but most of them is to do if I ever win the lotto
