here's a quick one for you guys... where have people found is the best place to install water and oil temp. sensors on an rb25... obviously the water temp. sensor could be installed in the stock ones location but the oil temp. where to put it?
please help before I do something silly and start drilling into the sump :D
https://www.sau.com.au/forums/topic/106693-oil-water-temp-sensors/
The sump is the best place, if you don't have an oil cooler and/or remote filter. They usually have threaded holes for the pressure and temp fittings. The sump has to be removed to weld on the fitting for the temp sensor.
:P cheers :D
i am in a similar sort of position with the oil temp someone mentioned a while ago about getting an adapter plate that you screw onto where your oil filters goes on wouldnt this give a more acurrate reading of your temps than the bottom of the sump ???
only trouble is i have not been able to find this adapter plate
Exactly. It's a plate that goes on the bottom of the oil filter. Just Jap sell it for $30.00 (no plug intended)
hmm i had a look on there site do they actually have it listed there... if i dont find it soon i might give them a buzz :D cheers for that
