Ok I have a few simple q's here.
At the moment I have an its Turbo wich makes good power (approx 230rwkws) but my god its a laggy beast. I get the kick in the back at 4500rpm and dont get full boost 16 psi till 6k
I want to still be able to achieve this power level but I would like some little mid range back.
The HKS GTRS seems to be the way I am leaning towards.
How laggy are these on the RB20?
And I have heard they are good for max 250rwkws?
Is there anything else I would need to know about it?
My current mods are:- RX7 550cc injector, Blitz FMIC, bosch 040 fuel pump, Z32 afm, Remapped ecu, Oil catch can, etc so supporting this sorta power is fine.
Thanx guys. :P
https://www.sau.com.au/forums/topic/106698-hks-gtrs-rb20det/
  • Replies 45
Thanx guys. :P
Probably still a little laggy on a RB20 better suited to a RB25. The HKS GTSS and HKS 2530 are a good match for the RB20 a cam gear or a set of cams will help to
cheers
on a side note, anyone have any experience with a T518Z on an RB20?
they seem to be exremely well suited to the SR and one particular example in latest ZOOM mag is making close to 260rwkw with 1.4 Bar boost with great response.. other mods too obviously but still, this turbo seems to be a good deal for the SR20... maybe get similar results with a little more lag in the RB20...
I'm not 100% sure but I seem to recal them being 440hp??
Edited by GTST
This is the interesting thing...why more lag. Was comparing my RB20 plot agaisnt as SR20 with the same turbo, makign the same power down to abotu 2rwkws difference. His engine had cams and mine std, and they were eseentially the same, actually i recall the RB20 had it by a bees d1ck :D
The T518Z woudl be interesting on the RB20, though i believe it is only T25 flanged, not T3...so bugger.
2530/gtss have been recommended highly for the rb20. Naturally, the rb20 has less spooling power than the rb25, so that's why people use these smaller turbos.
Based on the results obtained by other forum members, a 2530 on the rb20 wouldn't make much more than 220 rwkw as mentioned above, but it will be almost as responsive as the stock turbo. Although it will be about 10 rwkw less than you have now, it will actually feel a lot quicker, because you have more average power. That is, compared to your current setup with nothing nothing nothing, BOOM big power.
If the t518 is good for 440bhp, then perhaps it is quite comparable to a GCG highflow of the rb25 turbo? the gcg highflow is apparently good up to 450bhp with the supporting mods.
OK I translated the HKS site
( http://www.hks-power.co.jp/products/turbo/...rs/ac_gtrs.html )
on altavista bablefish.
( http://babelfish.altavista.com/ )
And I managed to get these specs for gtrs.
Power ------- 400 ps
Front Compressor
A/R = 0.60
Trim = 52
Entrance diameter (mm) = 51.2 mm
Major diameter (mm) =71.1 mm
Rear Turbine
A/R = 0.64
Trim = 76
Major diameter = 53.8 mm
Exit diameter = 47.0 mm
I'm dont really know much about this sort of stuff but maybe someof the turbo gurus could comment?
Going on the HKS Site this turbo is supposed to be as reponsive as a GT2530 but with the top of a GT2540.
So 240 to 250 rwks?
Is this just a marketing gimick or does this sound right?
yeah roy your right about the T518Z its t25 or t28 not sure but they have that with sr20s and the rb20 the have td0516g and 18g with 25 in the auto barn ad and the say these are on stock manifold i thought the tdo5's with external gate?? my mate has s15 with T518Z and its flying on stock boost he has injectors maxxing out its around the 200kw mark
I actually like the GT-SS if you want mid range punch , its basically a 2530 with a 60 trim compressor instead of a 63 . I don't think I've seen a 2530 with the comp cover off and don't remember its cartridge number so can't confirm if its a late design wheel . I'll have a look at the 60T comp map to get some idea of its airflow / power potential .
I can see the 4 to 6 cyl 2000cc comparison creeping in again , don't forget the SR20's pots are ~ 1.5 x RB20's pots and the exhaust slug or putt to the turbine is significantly different - enough to allow the 4 cyl a .86 a/r turbine housing where the 6 seems to be quite laggy with it and probably needs the .64 a/r housing .
My 2 cents spent cheers A .
From turbobygarrett/products/turbochargers/small frame the maps look like this though the turbine housing used here was Garretts T28 flanged .64 housing . It'd be nice to think that the T3 flanged HKS equivalent would be better inside . I'm not sure which comp cover HKS use on the SS but it may be the slotted or port shrouded type used on the 2530KAI if its the 6 cylinder model specific version .
Note how HKS have changed their thinking with older turbos like the 2510 and 2540 and the result has been the GT-SS (more open bladed turbine and smaller trim compressor) and GT-RS (smaller 71 vs 76 mm compressor of a more modern design) . The gain is response and far better compressor to turbine load balance .
HKS turbos can be expensive but they bolt on where Garretts often don't and cost lots to adapt . You have to do the sums to know the final figure .
Cheers A .
The T518z is the T25 flanged TD05H-18G. It has custom housings on both sides to make it a true bolt on for an SR20. This includes bolting onto the stock dump pipe, stock hot pipe and stock air intake.
My pal with the T518Z on his S14 is now making 275rwkw, thats pretty phat!!!
Btw Roy with cams I found my SR20 lost fair chunk of low down torque, I really dont like it. Its like I'd get blown away by even a 1.6L pulsar unless I have it above 4000rpm.. just a note...
Also I think the GT-SS is a waste of time being a 60 trim compressor. Thats no bigger than the standard turbos on the S14/S15! (Turbine is better though).
60mm compressors move a fair bit of air if you spin them fast enough , I don't call ~330 wheel horse power too shabby . S14/15 BB GT28's are limited by a Nissan specific GT28 compressor and garden variety (for a GT28) turbine /housing/dump and exhaust manifold . If you used the GTiR manifold and a GT28RS (GT2860RS) the difference is huge . Not all 60mm compressors are equal and uncorking the exhaust side lets the engine see a whole new world .
Cheers A .
i would well and truly choose the gtrs over a gt30 anyday.. especialy for its direct bolt on feature were as gt30 top mount mani, gate, blah blah blah you know the usual big snail mod
the gtrs is well and truly capable of making 250rwkw on a rb20 with the supporting mods ive found the garrett equivilant and a friend of mine is tryin that soon on his rb20 so will be awesome to see
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
