  • Replies 45
Yes i tend to agree, my ECU was tuned by a local tuner. I did ask him to go easy as I want to be on the safe side.. I would however like to go further than 6800RPM my japanese cutoff was set at 8200RPM I still wonder how comme my 400 injectors lean out, or is it the tuning/turbo.. I wanna start downloading ecu .bin soon enough to see how my fuel map is..
And yeah 94 octane gas is as good as it gets here but I've seen/read that 94 here is about like 98 japanese octane...
is running that rich leaning out my injectors when I pump the boost up?
What sort of fuel pump are you using?
Unless you fuel pump is capable to flowing enough fuel to hold solid rail pressure at higher injector dudty cycle you will see it start to lean out.
Also if u are using the stock afm that may cause a problem as it may be maxing out aswell.
Increasing timing wont reduce your boost threshold. In fact It will do the opposite. There is a big compromise here between lag and power.
So if you actually run very retarded timing it can cause the fuel mix to burn very late while leaving the cylinder and hence a sort of antilag?
Hmmmmmmmm I can see how this would work.
i doubt it, antilag works by adding extra fuel in to burn in the manifold and thus give extra exhaust gasses. changing timing enough will just cause a late burning of the mixture but its still the same amount of air/fuel, so still pumping out the same amount of exhaust gasses, just burning later
maybe the higher EGT's will help though
Edited by mokompri
RedDrifter I have
-440 Injectors
-Z32 MAF
-GTR Fuel pump
-GTR intercooler
-2.2L Tomei engine Derive I
I didn't have a boost gauge when the guy ran the dyno so I do not know if it's the boost that drops above 6800.. I'll repost my graph here to help you guys
You can see the A/F leaning around 6800...
Edited by klys
Yes, thats exactly correct, problem is that you will have heaps of boost but very little power, hence the compromise.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
