Hey guys this is not a add or a shameless plug.
I am a full lic. mechanic that is currently working in the high performance brake industry.
Apart from that i would be happy to assist with any brake related questions and become part of Skylines Australia community
Cheers
Brian
Here is some pictures of some of the kits i fit to Skylines.
front kit fitted to a R32 GTR
genuine AP racing
rear kit from AP racing
This one is a R34 skyline kit from Brembo that has 2 piece rotors front and rear.
Brian :P
https://www.sau.com.au/forums/topic/106715-skyline-big-brake-kits-pictured/
how much would the AP front and rear setup for a GTR roughly cost? And how big are the rotors?
WLDCRD
I can say that AP kit isn't cheap
I would prefer not to talk money on the site without invite from admin to do so
But I am happy to talk about the kits or diagnostic questions :(
the front rotors are 362mm x 32mm strap drive floating disc. Latest rotor from AP racing
the rear rotors are 332mm x 24mm 1 piece
Cheers
Brian
Cheers
Brian
Hi Brian I have been having some trouble my abs unit in my R32 GTR recently and was hoping that you might know of this problem or heard of it around the traps.
On Sunday I started my car and the anti lock light came up on my dash, I check the fuse link in the engine bay and it was blown, I changed the fuse and the left hand side indicators all stay on, I also checked the unit in the boot and the led flashed 8 times.
I have also checked the Actuator terminal and it seams to be ok, maybe the Actuator Relay could be dead, :)
Sorry for hijacking this thread like this but I though I might ask hear because of Brian’s expertise, any help would be great
Zardos
Electricals are tricky one to work out without the car.
I think your onto the right track checking the relay.
It does sound like a problem that S13's get when lowered and a group of wires coming through the firewall get scrubbed by the wheel causing multiple components to work at the same time. You may have to give me a couple of days to give a more thorough answer concerning the R32 as i'll check with a few mates in the game.
If anyone else has had this problem resolved please help Zardos with some info.
Brian
Hey Brian,
Not sure if you can point me in the right direction and I have heard from others that there is probably not alot I can do but I bought some DBA 4000 slotted rotors about 8 months ago for the front along with a new set of Race Brakes DB74 I think. Anyways the last two months braking at low speeds they squeal like they have just been raped the only way I have found to avoid this is to brake quite firmly as I am stopping then it does not do it. Could it just be the compound of the brake pad eg the low braking pressure is causing it to not really bite in hard enough and as such squeal alot ???
Any advice would be good as this did only start happening a month or two ago. I am going to pull the wheels off later this week and make sure the shims and all that are still seated correctly.
Cheers Leigh
But I am happy to talk about the kits or diagnostic questions ;)
Cheers
Brian
Leigh
That's a very comon complaint about high friction pads
A couple of tricks u can try are. Shamphering the leading and trailing edges off the pad, useing a copper grease between the shims or using galfer anti squeel shims.
I use the combination of shamphering and Galfer's anti squeel shims on my drift car as it runs R32GTR front brakes with DS2500 Ferodo racing pads. That did the trick.
Brian
Zardos
Brian
thanks very much for helping me out brian, as you said Electricals are tricky and very time comsuming which i want to avoid a auto elect because it could take them a while to fid the problem and at $55 per hour i would rather do most of the ground work my self before i go there, just to save some dollars.
Once again thanks guys.. :P
Pistonfreak, I am happy to have your knowledge on the forums and provided you dont try to sell your products directly, I am happy to have you post rough prices for the members. In my opinion its the one area of cars that is still very grey, not many people know enough about braking.
Hope that helps,
Christian
Hope that helps,
Christian
Thanks Christian
No interest in sales. As I'm the Mechanic at V-sport (the sister company to BSM and competition friction)so I don't get a com. on anything sold. :P So if you need prices direct them to the companies mentioned as if you have looked them up for yourself. I don't get to see much priceing anyway
As stated I can help with tech info if needed. B)
I work with R&D of race brake systems and do tech support at the race track (Gee works hard). And the fitments of genuine Brembo and AP racing brake kits.
the rough ball park figure of the systems pictured is around $10,000 front and rear.
Would you mind if i just added a link to the V-sport site to my signature
Cheers
Brian
$10k +
:P
If any car needs better brakes it's a GT-R. Especially the R32 GT-R. I've upgraded the fronts to R33 GT-R Brembos and they're better... but still not great.
Question then. Simple one too. Would it be AOK if I was to just upgrade to 6-pot front brakes and leave the stock R32 GT-R brakes on the rear? I know this would be un-balanced but how bad would it be? Worse than just living with the Brembos I have on the car now? Or still... better?
$10k +
:P
Justin,
You need to match the piston area in the calipers if you are to keep the front/rear bias as is presently is. The Brembos have an area 5300mm2 so look for a caliper that has a number close to that. Bigger pads will help too as the Brembo's pad is basically the same size as the stock R32 pad, ie 116 x 50mm.
Hey pistonfreak
I've got a r33 GTST skyline that I take out to track days a few times a year. Last track day was Tuesday this week and I ran into some big brake fade issues. Firstly I noticed something was wrong when I came back into the pist after 5 hot laps of the clubman track at QLD raceway, the pedal felt mushy but I was still able to get adequate braking and with a few pumps of the pedal the pressure came back up... but dies off again after a few seconds (I did not have braking issues while on the track). This went away as the brakes cooled.
Firstly can you give me any idea why this was happening and how do I fix it.
The next time I noticed was when it had more serious concequences, I was on the 5th lap of the national circuit at the end of the main straight going 190km/h, when I got on the brakes not much happened, I knew what was happening but it was still unexpected because there was no warning. I ended off in the kitty litter at around 100km/h.
Specs of my current setup:
1) Standard rotors front and rear (fronts machined just before the track day so down to about 28-29mm thick) Standard rotors are not slotted and are 297mm diameter.
2) Standard calipers front and rear.
3) Feredo pads front (brand new before track day), Nizmo rear (older but plenty of meat)
4) Standard brake lines.
5) Motul RBF600 DOT4 fluid
6) Backing plates still installed.
7) master cylinder support
My car is not a serious track machine and is still putting out pretty much stock power (exhaust and pod mods only) I've done a bit of work on the suspension - nizmo struts front, bilstien rear, standard springs, whiteline swaybars, HICAS removed, subframe bushes, front strut tower brace. I don't ever plant of putting out more than 200rwkW and I'm pretty much happy with the suspension. I'm currently lapping the QR clubman track at 70 seconds flat.
Can you give me any advice on a economic setup to prevent this in the future? I dont want to change calipers and I'm not all that keen on adaptors for the callipers to fit bigger rotors (I'm sure they would flex too much causing more problems - what is your opinion?)
My plan was to remove the backing plates front and rear, install braded brake lines and use some DBA4000 sloted brake rotors up front. Does that seem like a reasonable setup? Will this setup keep me going (stopping :blink:) if my power output goes up?
Some tricky questions I know, but if you can shed any light on the issue at all it would be greatly appreciated.
Thanks,
Patrick.
Patrick
There is some reasons for this happening, It is because you live in a humid climate in QLD, and your system will absorb alot water.
The upgrade to braided lines will help pedal pressure and stop from absorbing so much water
removal of the baking plates is also a great idea and works well in reducing temps.
I would strongly advise moving up to a 660 degree AP racing fluid
DBA 4000 series slotted rotors will work well also.
It seems you are on the right track and answered your own questions well.
Cheers
Brian
Cheers
Brian
genuine AP racing
Are they 7600 rears? Or have you increased the rear rotor size as well?
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
