Tell me about it. I got an email today saying funds have cleared, and are being shipped, so i wont expect them to be hear till monday if thats the case.
so do you have them today?
:D
  • Replies 181
Posted Images
Nope, and im not frikking happy either. Ive paid for overnight courier to me (at my expense) and they still havent arrived. Ive spoken to them just them, and explained im not happy at all, as ive paid, and been told these would ship thursday last week.
Ill keep u informed....
I HAVE THE BUSHES!!!!!!
miracles do happen. :O
Ok guys, im packaging these up and sending them out, so it may take me a day or so to get them all done and out (ive got a dozen here to do). Hope u all get a nice suprise soon :P
Thanks for taking part in the GB, and NO im not doing another :(
Just looking at them, and they are definitly smaller than the r33 bushes as well for those who are wondering, so fitment may be easier.
Edited by Bl4cK32
Can all u guys who havent sent me a pm with your address please feel free to do so. Ive got a couple already, and i dont know how to sent out a multiple message to the 10 other guys.
So if u havent yet, please do so....
I sent two lots out. I asked a member of my family to send out the second lot as ive got a bad back (disc problems) and foud it hard to get to the post office. I found that the second lot was only posted today, so dont worry everyone should have them by monday at the latest...
GTR1993 i can drop yours off as im in Adelaide, but the other side of town. If im going past on the weekend i can stop by, or monday at the latest. Pm me when someone will be home either sat or monday with a mobile number -
thanks guys.
Ps - if no-one has seen them by wednesday, lemme know and ill contact the post office to find out whats going on
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
