  • Replies 181
Posted Images
can we set a cut off date for payment? It just seems to be taking a long time for people to pay after expressing interest and i'm quite keen to get things happening. :D
sent u a pm mate :) To everyone else wondering about closing dates what happens is i need 5 people minimum to get the low price from Noltec. Once over 5 i can still get the same low price.
What has happened is i have enough people to place 2 separate orders through. Im taking the 5 guys who got in first and ordering their stuff now, and the last 5 guys who payed me (or im waiting for) will have to wait for that separate lot to be payed in full to get their group order of 5 placed. It shouldnt take too long for their order to be paid anyway.
Thanks everyone so far.
sent u pm too :)
Look guys as i said above ive got enough orders now to cut off the first group and place an order through.
If you have ordered a while ago u are on the first list. (if unsure pm me and i can tell u on which list u are on)
I did say about this happeneing in my first post though of the gb. Sorry i shouldve said what was going on with the orders again to make it clearer.
Beer Baron / Roy: Sorry I've been so slow to get around to this. As I explained to Bl4cK32, I've been the only one looking after work for the past fortnight (everyone pissed of on an overseas training junket) and just haven't had time to organdise (winnie the pooh stylee) payment, etc for this. Hope it doesn't cause any major inconvenience.
haha i wasnt talking to you mate. you have paid ;) I was just trying to stimulate some more people that had said 'in' into paying up so we can get the show on the road. :D
PM sent again Darren, just let me know when to send bud. :D
P.S - have you started or are you going to start a group buy for other Noltec products? Mainly the camber/caster radius rod bushes you were talking about before? I'd be pretty interested. :)
Quick update guys - R32 subframe - I rang Noltec to confirm stock levels. They only have 3 on the shelf. Not to worry he said, as they are running more as we speak, and they should be in soon. As soon as they are in, the order will be placed.
This happened with the r33 bushes as well, no big dramas though, as they came thorugh earlier than Noltec said. So we should see some soon :(
Sorry for this delay guys....
Guest
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
