Hello
I am new to this forum site.I would like to know what is the highest HP at the Rear Wheels produced by an Rb25 motor.
I currently have a GTST skyline and with the standard Rb25 motor and pumping out 498 Hp on 18 PSI.It is a manual skyline.I am running a Standard Motor,GT3540 turbo,Custom plenium,750cc Injectors,Hydra Computer,125 mm thick cooler with HKS style end tanks,3 " intercooler pipes, 3 "exhaust,Aftermarket coil packs.The engine has been run on the dyno about 150 times checking things and testing as i am trying to prove what the standard rb25 motor is capable of.
I am wanting to see who has made more hp.A dyno sheet is available and the dyno is on my own Dyno Dynamics Dyno running shootout mode.Intake Temps on the dyno sheet are 34 degrees and the room temp is 30 degrees.
Thanks
PS this is on Opitimax fuel.
Edited by LNEMUP498HP
https://www.sau.com.au/forums/topic/106775-max-hp-out-of-standard-rb25/
Yeah buddy
im going to be using this car for drifting and drag.
Its my business vehicle.I own Wild 1 Motorsport along with my Father.The vehicle is going to get rego next week as while i was building it i ran out and yeah i will be driving it.
Yeah completely standard. I Have got another motor i am building with h beam rods, Forged pistons,ARP main,conrod,Head stud kit,Cometic head gasket,Tommie cams and springs which i will be dropping into the car as soon as something goes wrong with this one.I thought i will prove ppl wrong about the standard motor.
498hp on std rb25...mate that is impressive. Now we just gotta wait for someone to come along and say 'thats a load of the "proverbial"'
What sort of knock you getting on your current tune?
  • Like 1
i am going to put the new knock sensor on tomorrow.The old one would detect to many vibrations for the engine on idle.
When i used the stithoscope or however you spell it.The knocks were very minimal.I am going to using c16 in it and see the power difference.
As for the Dyno graph I will do it with Hp And Boost to shut ever one who doubts it up.
If no 1 believes its standard. They can pay me to pull the motor out and if it is they can pay me if it isnt i will pay them.
No 1 should Doubt the POWER OF a NISSAN RB motors.
Nice work on the power figure :D
GT35's tend to make power well.
I dont think standard means much at this stage...
Make it last 12 months with SOLID work... and make sure you post backup if its still running as thats the real test, one that no-one has passed.
No winding down the boost either :O
You so adamant about "shutting people up" what are you trying to prove?
Anyone can run big power in a stock motor. A few power on the dyno runs doesnt impress anyone but the 15yr old kids :D
I saw 500rwkw+ from an internally stock RB26.
Needless to say it lasted not very long at all and died a dismal death
LOL
turn the boost down
the boost isnt going anywhere.
as for the motor
if it blows ahh well
i got my back up motor waiting.I wanna push the engine to its limit
runing just under 18 psi wont hurt the engine the head gasket is the only thing i see wreaking and the engine is reving to 7500
i will keep every one posted on how the engine goes and lasts.
You still have a little way to go, I have seen 550 rwhp out of a ZeniTani built R25DET (standard internals) using a hi mount T78. But like all RB25's with more than 320 rwkw, it didn't last very long.
It's not about "how much" power, but for "how long" it makes that power.
I have a question;
Hydra Computer
What ECU is that?
;) cheers :)
Edited by Sydneykid
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
